Question about Saws
I have a 3 hp smith and jones motor. The wires coming out the motor r labeled t1 t8 t5 t4 and p1. I have white black and green coming from the switch on my table saw. Don't know what to connect where. Help!
  • 8 Answers
SOURCE: Hi I have a farm
there is normally a name plate on the inside of the cover that shows high and low voltage connections without that the connections could be a couple different ways. Have a look Im sure its there
Posted on Jan 21, 2009
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
rockitman187
  • 2559 Answers
SOURCE: Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: on/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Posted on Feb 25, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
Wiring a smith and jones 1 hp electric motor for 220. The diagram is not very helpful. I have a red and black hot lead and a white neutral. Where do they all go? I want to make the motor go ccw.
Ok from what I read on the diagram take one lead to P1 cap of P2 T3 T8 and T2 are together and T4 and T5 are put to the second lead
If you want to change direction exchange T5 and T8
Feb 11, 2017 | Smith Pool & Spa
Hello i have a smith+jones 67839 trying to figure out what wire i need to use for 220 the wires coming out of my unit are red white an brownish need to connect to my motor and they are all black
I corrected the spelling but I need to know what you are hooking that motor up to! The wires in the motor are labeled P1 T1 and so on. But the wires coming to the motor are from what?
Jul 30, 2016 | Pool & Spa
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Apr 12, 2015 | Hobart H600 Stand Mixer
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
Need to know what wire goes to were..on a smith & jones modle 67841 compresser motor..p1 p2 t2 t3 t4 t5 t8..to what wire black white green
Hey guys, this motor is reversible. I have it wired to turn clockwise(according to diagram),
green to ground;
L1 (black) to P1;
L2 (white) to T2-T4-T8;
P2-T3-T5 together .
When I plug it in, the motor turns counter clockwise and the on/off switch does not work. How do I fix?
Oct 27, 2012 | AO Smith A O Smith Motors Centurion 1.5hp...
How to conect 3 phase motor 9 yellow wires from p1
Connect t4,t5,t6 together. Connect t1,t7 together for line 1. Connect t2,t8 together for line 2. Connect t3,t9 for line 3.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
I NEED TO REWIRE A DOERR LR22132 ELECTRIC
The green should be connected to the chassis, it is ground.
There should be a wiring diagram on it to tell you how to do this, but if not:
There may be T-leads on the motor labeled
P1, P2, T3,T4,T5,T8
P1-L1(black wire)
P2-cap/tape don't use.
T2,T3, and T5 wire nut together
T4,T-8 wire nut together with L2(white)
The power leads will be coming from your switch box on the compressor body itself. Don't wire the 220v directly to the motor, you replace the leads where the first motor was connected on the cutoff switch. There will be only 2 leading from the switch to the motor.
Mar 24, 2010 | Plumbing
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
Hi I have a farm duty 1/2 hp dual voltage, single phase, capaciter electric motor. I simply want to attach a plug for 110. My problem is there are 9 wires colored and Labeled as follows Y/Black- P1 Br- P2...
Jan 21, 2009 | Heating & Cooling
Saws Logo
71 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
