Question about Refrigerators
HOW TO REMOVE DOOR - Refrigerators
  • Refrigerators Master
  • 744 Answers
Hello Davis;
My name is Peter. I am a retired field service refrigeration technician.
You are not going to get any response to your question because there are several different types of door attachments.
You need to provide your model number, which is located on a label on the upper inside wall of your fresh food section.
Posted on Mar 30, 2015
How to replace the door blend actuator on 2009 lincoln mks
Right side or left ? Electronic Automatic Temperature Control or manual ? Temperature or mode door ?
Temperature Blend Door Actuator - LH Removal and Installation
NOTE: It is not required to install the new LH temperature blend door linkage parts included in the LH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
LH temperature blend door actuator and linkage
  1. Remove the 2 lower steering column opening cover bolts.
  1. Detach the lower steering column opening cover.
  1. Disconnect the in-vehicle temperature sensor aspirator hose and electrical connector.
  1. Position the instrument panel wire harness away from the LH temperature blend door actuator.
  1. Remove the 3 LH temperature blend door actuator screws.
  1. Disconnect the LH temperature blend door actuator electrical connector.
  1. Remove the LH temperature blend door actuator.
  1. Manually operate, and inspect the LH temperature blend door linkage for incorrect placement, binding or damage.
Temperature Blend Door Actuator - RH, Dual-Zone EATC Removal and Installation
NOTE: It is not required to install the new RH temperature blend door linkage parts included in the RH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
RH temperature blend door actuator and linkage
  1. Disconnect the glove compartment damper from the glove compartment.
  1. Remove the glove compartment.
  1. Remove the RH lower instrument panel insulator.
  1. Remove the RH lower floor console trim panel.
  1. Remove the 3 RH temperature blend door actuator screws.
  1. Disconnect the RH temperature blend door actuator electrical connector.
  1. Remove the RH temperature blend door actuator.
  1. Manually operate, and inspect the RH temperature blend door linkage for incorrect placement, binding or damage.
  2. Mode Door Actuator - Defrost/Panel/Floor Door
  3. Removal and Installation
    NOTE: The defrost/panel/floor mode door actuator can be accessed from below the driver side of the instrument panel.
    NOTE: It is not required to install the new defrost/panel/floor mode door linkage parts included in the defrost/panel/floor mode door actuator service part kit if only the mode door actuator requires replacement and the linkage parts are not broken or binding.
    Mode door actuator and linkage
    1. Remove the 3 defrost/panel/floor mode door actuator screws.
    1. Disconnect the defrost/panel/floor mode door actuator electrical connector.
    1. Remove the defrost/panel/floor mode door actuator.
    1. Manually operate, and inspect the defrost/panel/floor mode door linkage for incorrect placement or damage.
    Mode door actuator linkage only
    1. Remove the mode door linkage.
      1. Depress the tab and remove the panel door lever.
      1. Remove the floor/defrost door intermediate lever screw and floor/defrost door intermediate lever.
      1. Pull straight outward to remove the floor/defrost door lever.
    1. NOTE: When installing the mode door actuator, make sure that the panel door lever and floor/defrost intermediate lever are correctly aligned with the mode door actuator cam.
      To install, reverse the removal procedure.
Nov 10, 2016 | 2009 Lincoln MKS
NEED TO REMOVE DOOR PANEL ON A 2004 CHEVY AVEO
Click the link below:-----Door Panel Removal?
How to remove the door panel to install a new window regulator?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
Hummer H2 Door Panel Removal? http://technoanswers.blogspot.in/2012/07/hummer-h2-door-panel-removal.html Hummer H2: How to remove Front Door panel? http://www.howtobyme.blogspot.com/2012/07/hummer-h2-how-to-remove-front-door.html 2009 Hummer H2 Door Panel Removal http://schematicsdiagram.blogspot.in/2012/07/2009-hummer-h2-door-panel-removal.html
how to remove window motor on driver side door panel?
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
Keep updated for more help.
Nov 19, 2012 | Cars & Trucks
Remove door panel
Expedition Trim Panel Removal
NOTE The door glass must be completely raised.
  1. Remove the window control switch plate.
  2. Remove the door handle bezel.
    WARNING To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
  3. Remove the two bolts and three screws, and remove the door trim panel.
  4. Remove the finish cover to access the two center screws.
  5. Disconnect the electrical connectors.
    Fig. Expedition - Trim Panel Screws shown
  6. Remove the door handle bezel.
  7. Use service notch.
  8. Remove the two bolts and three screws, and remove the door trim panel.
  9. Disconnect the electrical connectors.
    Fig. Navigator - Trim Panel Screws shown
  10. Position the water shield aside.
  11. If equipped, disconnect the lock cylinder rod.
  12. Disconnect the exterior door handle actuating rod.
  13. Remove the bolts and position the front door latch aside.
  14. Disconnect the electrical connectors.
  15. Release the interior door handle cable and remove the front door latch.
  16. Position the cable cover aside.
  17. Release the conduit and the interior door handle cable.
  18. Release the locking tab and remove the front door lock actuator.
  19. To install, reverse the removal procedure and note the following:
    1. Tighten the door latch screws to 80 inch. lbs. (9 Nm).
This procedure is followed to check and fix door locks.
Hope helps.
Jan 12, 2011 | 2001 Ford Expedition
The left rear door window fell off the track. How do I remove the door panel to access it.
This is the complete procedure you stop when you see the problem.
1. REMOVE REAR DOOR INSIDE HANDLE BEZEL
(a) Remove the screw.
(b) Using a screwdriver with its tip taped, disengage the 2 claws A.
(c) Pull out the the rear door inside handle bezel in the direction indicated by the arrow, disengage the claw B, and remove the rear door inside handle bezel.
2. REMOVE DOOR PULL HANDLE
(a) Using a screwdriver wrapped with the protective tape, disengage the 2 clips and remove the door pull handle.
3. REMOVE REAR DOOR TRIM BOARD SUB-ASSEMBLY
(b) Disengage the 7 clips.
(c) Disconnect the connector and pull up on the rear door trim board sub-assembly to remove it.
4. REMOVE REAR DOOR INSIDE HANDLE SUB-ASSEMBLY
(a) Remove the bolt.
(b) Disengage the 2 claws and separate the rear door inside handle sub-assembly.
(c) Disconnect the 2 cables and remove the rear door inside handle sub-assembly.
5. REMOVE REAR SPEAKER
6. REMOVE REAR DOOR SERVICE HOLE COVER
(a) Disconnect each connector and remove the rear door service hole cover.
HINT:
Remove the remaining tape on the door side.
7. REMOVE REAR DOOR GLASS RUN
(a) Connect the window regulator switch assembly.
(b) Fully lower the door glass.
(c) Remove the rear door glass run.
8. REMOVE REAR DOOR WINDOW DIVISION BAR SUB-ASSEMBLY
(a) Remove the 2 bolts, the screw and rear door window division bar sub-assembly.
9. REMOVE REAR DOOR QUARTER WINDOW GLASS
(a) Pull out the direction indicated by the arrow, remove the rear door quarter window glass and rear door quarter window weatherstrip as a unit.
10. REMOVE REAR DOOR QUARTER WINDOW WEATHERSTRIP
11. REMOVE REAR DOOR GLASS SUB-ASSEMBLY
(a) Remove the rear door glass sub-assembly as shown in the illustration.
(b) Disconnect the window regulator switch assembly.
12. REMOVE REAR DOOR WINDOW REGULATOR SUB-ASSEMBLY
(a) Disconnect the connector.
(b) Loosen the temporary bolt.
NOTICE:
If the temporary bolt is removed, the rear door window regulator may fall and become deformed.
(c) Remove the 3 bolts and the rear door window regulator sub-assembly and the power window regulator motor assembly rear as a unit.
(d) Remove the temporary bolt from the regulator.
13. REMOVE POWER WINDOW REGULATOR MOTOR ASSEMBLY REAR
(a) Using a "torx" driver (T25), remove the 3 screws and power window regulator motor assembly rear.
14. REMOVE REAR DOOR LOCK ASSEMBLY
(b) Remove the bolt.
(c) Using a "torx" socket wrench (T30), remove the 3 screws.
(d) Slide the rear door lock assembly downward, pull out the link from the outside handle frame, and remove the rear door lock assembly and cables as a unit.
(e) Remove the door wire harness packing.
(a) Using a "torx" socket wrench (T30), loosen the screw.
(b) Disengage the 2 claws and remove the rear door outside handle cover.
(a) Disengage the 2 claws and remove the rear door outside handle pad rear.
Jan 03, 2011 | 2006 Toyota Highlander
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
How do i car door panels safely
  1. Remove the cover behind the inside door handle.
  2. Remove the screw from the bottom of the pull cup retaining the front door trim panel to the front door.
  3. Remove the two screws retaining the sail panel/speaker grille assembly and remove the panel/grille from the door.
  4. Remove the three screws retaining the front door trim panel to the front door.
Do not attempt to remove more than one pushpin at a time.
  1. Use a suitable tool to remove the pushpins from the door.
  2. Carefully lift the door panel away from the door.
  3. Detach the electrical connectors as necessary and remove the panel from the door.
To install:
  1. Installation is the reverse of removal.
Door Panel
This procedure applies to both the front and rear door panels.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 30; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos'; c17hydro_23.gif
Remove the cover from behind the inside door handle by gently pulling it out to release the retaining tabs
Remove the pull cup retaining screw cover and...
... remove the retaining screw from the cup and lift the cup straight up out of the door panel
Remove the two sail panel/speaker grille retaining screws and...
... remove the panel/grille from the door
The door panel is retained to the door by 11 retaining clips
Carefully lift the door panel off of the door and...
... detach the electrical connectors from the switches and remove the panel from the vehicle
Nov 13, 2010 | 1996 Ford Taurus
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
Actuator removal
please rate as solved if this is what you need. You will need to borrow a heavy duty riveter from autozone or wherever you buy the lock cylinder from.
Removal
  1. NOTE: The rear door window glass must be completely raised.
    Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the rear door trim panel. For additional information, refer to Section 501-05 .
Trim Panel —Rear Door, Expedition Removal
  1. Remove the power window switchplate (14524).
  1. Disconnect the electrical connector.
  1. Remove the rear door handle trim cover.
  1. Remove the rear inside door handle.
    • Remove the door handle bolt.
  1. Remove the rear door trim panel screws at bottom of panel.
  1. s2j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the rear door trim panel, do not pull directly outward.
    Lift upward and then outward to remove the rear door trim panel (27406).
  1. Remove the rear door watershield.
  1. Disconnect the power door lock actuator electrical connector.
  1. Drill out the power door lock actuator rivet.
  1. Remove and discard the screws.
  1. Remove the power door lock actuator.
    • Disconnect the power door lock actuator rod.
Installation
  1. NOTE: Use new screws when installing the rear door latch.
    • Use Heavy Duty Riveter to install the new rivet.
Jun 14, 2009 | 2002 Ford Expedition
Broken exterior door handle,passenger sider ,sliding
Got this idea from mpvclub.com: Get some stainless or aluminum sheet metal screws, drill pilot hole into the handle and into the receiving part behind, then screw in the screw. Do on both sides of handle (get appropriate length screw.) When done, get some putty or hardener to fill in the screw slot, let dry, then sand smooth, then paint with body color. Result is great and inexpensive.
Jan 26, 2009 | 2004 Mazda MPV
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
