Question about Kitchen Appliances - Others
My Franke kettle tap has stopped working properly the water tank keeps tripping why?
3 Suggested Answers
  • 9 Answers
SOURCE: MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
Posted on May 23, 2010
  • 267 Answers
SOURCE: My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Posted on Feb 04, 2015
Franke Little Butler not heating
If not tank filling ur heater wont start mostly ur soleniod valve for incomimg water spoiled. Also ur heater might be open or heater'$ thermal fuses open, if have.
Sep 22, 2014 | Franke Water Dispenser Tank Little Butler...
Franke water coming out of hot water handle after I changed the filter
It sounds like the cartridge is not properly seated against the O ring. I am not familiar with this exact model but remove the filter, check and be sure the o rings are ok and re install the filter.
Mar 04, 2014 | Franke LB2200 Instant Hot and Cold Water...
My kettle keeps blowing the circuit
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle.
Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
May 28, 2011 | Dualit 72300 Stainless Steel Cordless...
Franke Saphira - fill water tank
There is a magnet fitted in the side of the tank. Lift out the tank and make sure the magnet is free to move. It might be that some water has been spilt onto it and it's crusted up. Failing that, suspect a faulty microswitch inside.
Jan 24, 2010 | Franke Saphira Espresso & Coffee Maker
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Franke Little Butler instant hot water dispenser
I have the same unit and had a similar problem. If yours is the same as mine, look at the top of the water heater unit. The center spigot is for the for the how water outflow which is connected to surgical type rubber tubing. The hot water eventually dried out the tubing and it cracks, causing it to leak. I had to cut out the decayed portion and replace it. Franke sent me a replacement kit at no charge but I did replace the fitting on top of the unit. The fitting is a standard nipple that any HW store should carry. Mine is a female-to-female reducer that then mates to a nylon barbed fitting which the tubing goes into. Importantly the Franke supplied kit has nylon ratcheting hose clamps that keep the tubing in place as well as a barbed union with hose clamps to join to the exisiting hose feed (to the faucet).
Hope this helps! I'm now struggling with the hot water tap leaking after using it. It seems to stop after a while but it drips for some time. If you can help me there that would be great!
Apr 13, 2008 | Franke WD751B GPS Receiver
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Kitchen Appliances - Others Logo
215 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
