Question about Troy-Bilt Pony Garden Tiller
Won't start,charged oil,cleaned spark plug and air filter.has gas.
    New Friend:
    Problem Solver:
  • 7 Answers
If your tiller has sat for any length of time it may have stale gas and the spark plug may need replacing (not just cleaning). Always make sure all wiring and or connections are clean. You can check for spark by removing spark plug, insert it back into spark plug wiring, using a WOOD clothes pin to hold the wire, hold spark end of spark plug (holding the clothes pin only) on metal casing on machine, pull starter cord and check for spark. If you don't use a non conductive instrument such as the clothes pin you will get a nasty shock. If you have no spark it is time to change the plug. Always put your safety first! Hope this helps! Have a great day! If this doesn't work perhaps you will need more information.
Posted on Apr 01, 2015
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
2005 Yamaha 250 Rebel will not start
If you did not put in a new battery, try that. Your old battery probably doesn't charge up enough.
Nov 04, 2012 | 2005 Yamaha Xv 250 Virago S
Mower starts good but only runs 5 minutes befor stalling out and won't start again until cool. It idles OK when blade is NOT engaged. Cause? And how do you set the carb adjustment screws to max. p
No adjustment for carb on newer mowers. All mowers now have a low oil cutoff. Ensure oil is full. 30w oil. If any grey is observed vin oil drain all oil. Moisture in oil. Dump old oil out every 2 yrs and refill. Ensure spark pluf is clean and gapped correctly. Ensure air filter is clean. Replace spark plug and air filter each year. Always use Stabile in gas. Spray outside of carb with carb cleaner to ensure proper choke movement.
Sep 24, 2012 | Toro Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Troy-Bilt Pony Garden Tiller Logo
205 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
