Question about Farberware Skillet Frying Pan 12 inch Stainless Steel M2 Lid
I need a probe for model 103-A Where can I buy one?
Microsoft Wireless Optical Desktop Receiver 2.1 Model 1028 X800685-103 W/Usb
check the batteries and then see if the usb is properly fixed in the port, the green light should be on =)
Oct 22, 2012 | Microsoft Wireless Optical Desktop...
I need an owners manual for a Knight Kiln Model103
did you find a Knight Kiln 103 owners manual?
Dec 17, 2011 | Dryers
I need a manual for Dirt Devil Model 103
Hi mjuhnke...
Go to the following webpage and download your FREE user manual for your Dirt Devil 103...
Please take time to rate me thumbs up
http://www.dirtdevil.com/manuals/?id=74c976cc-0d1b-4100-bd8c-1f86dda0a9c8
Sep 18, 2011 | Dirt Devil Vacuums
Trippers on paragon 4003 are broken
Paragon 4003 uses x2772 tripper
http://waterheatertimer.org/Paragon-timers-and-manuals.html
1) As of November 2010 or before, Paragon is no longer making timers or parts except defrost timers.
4003 is not defrost timer.
2) Do google search for x2772 tripper.
I have seen x2772 tripper selling for more than a new Intermatic timer.
3) Intermatic has cross reference if you want to buy new timer:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
For example 4003-00 crossover to Intermatic is T-103
Grainger sells T-103 for $70
4) For T-103 wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
5) Add a comment with specific model number if you want more help finding replacement timer, or need crossover wiring.
6) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hardware & Accessories
Caldera spas hot tub Olympic model blows circuit breaker trying to heat up
Remove all pwoer and then gain access to the heater probe. Read each probe from the center connector treminal to the metal base with an Ohm meter. There should be no reading. If you have low reistance the probe is internally shorted and will need replaced. It is a common failure for a heat probe. If the probe is bad when you do buy a replacement buy the "Coated" element. The extra $15.00 is well worth the investment in the overall lifetime of heating element service.
Replacement elements can be found here
Thanks for using FixYa.
Kelly
Mar 22, 2010 | Pool & Spa
Where is the tach wire so I can install a tachometer on my ford probe 4 cyl 2.0 DOHC
you will need a wiring diagram to find that out ,and i do not know on this model ,how about buying a haynes handbook that should tell you
Mar 20, 2010 | 1995 Ford Probe
We have Model #FEB 386WECH and after getting
That's the last time you buy that brand.
Usually Frigidaire is rated pretty high. I would say you should check reliability of a model before you buy.
It will get worse, the more digital these appliance's become the more problems there will be.
The old way is easy to fix, you can't fix boards and pads, they get replaced. But with technology growing so fast,they are not keeping parts for long.
You should call the company and see what they say, if your nice, maybe they can offer you a discount on a new one.
Does not make sense that this repair man did not know the pad was bad until after the probe, something seems weird with this.
Feb 15, 2010 | Frigidaire Ovens
Is ecomed finger probe compatible with welch allen equipment
there are several diffrent versions of these moniitors and diffrent probe types. What is the model number of the machine and serial number? Does it have a sticker on the machine that says "Nellcor" or "Masimo" or "Oxyworks"? You will need to know that before buying a probe.
Sep 30, 2009 | Welch Allyn Vital Signs Monitor with Nibp...
1999 windstar sel. left rear tail light inop.
Switched system power relay #4 supply's B+ voltage to center wire -red with yellow trace. Fuse 103 40 amp supply's B+ voltage to the relay .
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. Year , make , model and engine size. Under system click lighting .Under subsystem click on exterior lighting . Click the search button ,then the blue link .Third diagram down is the one for the rear tail lamps .
Jul 25, 2017 | 1999 Ford Windstar
1993 Ford Probe needs motor mounts
is the model with the V6 mazda motor, if so it can be a bit difficult if you have little mechanical experience, but it is doable without removing the motor or transmission. we would allow 3 hours to complete the whole job.
Dec 23, 2008 | 1993 Ford Probe
Farberware Skillet Frying Pan 12 inch Stainless Steel M2 Lid Logo
371 people viewed this question
Top Farberware Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Farberware Hardware and Accessory Expert? Answer questions, earn points and help others
