No volume and visual menu looks funny, nit responding well
How to hard reset prestige eliet visual land tablet
Hard Reset To hard reset your Visual Land Tablet, you need to follow the instructions below carefully.
1. Turn off the tablet.
2. Press and Hold Volume Up and Power button at the same time.
3. Keep holding the buttons till you see the start up screen.
4. Press Volume up five times when you see the android with an exclamation to reveal the recovery menu.
5. Since touch screen doesn`t work on this mode use Volume and down to move on the menu and power button to select.
6. Select Wipe Data/Factory Reset.
7. Select Yes- Delete all user data.
8. After the wiping select Reboot System Now.
Apr 01, 2017 | Tablets & eReaders
How do I reset my visual land android tablet
In the settings menu you should find a back up and reset option. Or on most android devices with the unit off press and hold the volume up and power buttons. Continue to hold both until it boots to the android menu. Use the volume up and down to scroll and power to select. Select factory data wipe. If yours does not have a volume control then there should be a recessed reset button usually located on the back of the unit. Insert a paper clip and press and hold.
Oct 12, 2016 | Prestige Visual Land 10" Tablet Android...
Visual land ME 965L buttons won't work
Hit the "reset" button on the back, lower right of the player.
Dec 31, 2011 | Visual Land V-Touch Digital Media Player
Volume problem the mute sign comes on but no volume. The caption works
Ensure that your AUDIO MODE is not set to SAP.
Check the AUDIO MENU and confirm that it is either MONO or STEREO.
SAP is the Secondary Audio Program (decriptive video for visually impaired) and will not always have sound on every channel.
Also ensure that your SPEAKER SETTING in the AUDIO OPTIONS MENU is NOT set to OFF.
If it is not simply a setting problem in your menus, then it may be a hardware fault in the main circuit board. If this problem occured just after a power failure or a brief power flicker, then it is certainly possible a component was damaged on the main board and is affecting only the sound.
Please comment back here to this page if you have any questions or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
Feb 20, 2011 | Vizio VO47L 47 in. LCD TV
Volume/sound will not increase up on my Samsung HL61A650
If the volume indicator appears and respond as you increase the volume but the sound does not respond, there might be a problem on the audio section.Ask for a repairman to check it. If the indicator does not respond, try using manual control instead of using remote control.Also some units have features to turn speaker off or on. Go to menu scan for audio check if it is turned off or on.
Oct 21, 2010 | Samsung HL61A650 TV
Unable to get remote to respond to up and down on channel or volume
Check Battery On the Remote... Check On front Panel TV Look for on off remote also look under menu setup
Oct 07, 2010 | Hyundai ImageQuest HLT-3270 Television
Low volume on Nokia 1600 phone
sometimes the volume is in a funny place. did you try going to menu then settings then audio/ringtones then volume? I hope this is helpful
Jan 15, 2009 | Nokia 1600 Cellular Phone
2nd gen ipod nano has a frozen screen and won't respond
SOUNDS FUNNY BUT LEAVE IT ON TILL BATTERY DIES THEN FULLY RECHARGE.IT WILL RESET ITS SELF AND SHOULD BE FINE.IF NOT GET BACK TO ME FOR FURTHER INSTRUCTION.RICHARDM69
Dec 04, 2008 | Apple iPod nano
I need to access the television menu screen
the tv's that dont have a menu button on the front will usually switch to menu by pressing either both chanell buttons at once or by pressing both volume buttons at once if this dont work let me know.
Dec 22, 2007 | Televison & Video
Samsung TXE1370 13" TV - volume out of control
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
Feb 25, 2007 | Samsung TXE1370 13" TV
51 people viewed this question
 Grubhead
Grubhead
