Question about Water Water Heaters
My hot water tank for the tap keeps tripping why?
  • 3 Answers
The fuse inside of the hot water heater keeps tripping and i have to keep pressing the reset button. why is this? i tried turning down the heat level but it still does it. does anyone know what the problem is?
Posted on Apr 06, 2015
  • Water Master
  • 5,245 Answers
gary1121
  • 332 Answers
SOURCE: no water coming out of carver cascade water heater
is the cold side hooked to the cold side if not you will be feeding the unit backwars making it to where the cold is just comming across the top of the tank, check the dip tube also, this makes the cold water go to the bottom and push the hot out of its outlet,, how many faucets are involved, if just one might want to check the cartridge to make sure it is working properly
Posted on Jun 21, 2009
  • 35 Answers
SOURCE: I have a thermostat mixer shower but hot water has
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Posted on Feb 19, 2010
  • 608 Answers
SOURCE: hot water gets too hot trips off at tank then
It's time to replace your thermostat. Instead of maintaing the correct water temperature, the water is getting so hot it is acivating the safety circuit breaker. If this breaker were to fail, you could have a devastating explosion
Posted on Mar 21, 2010
SOURCE: need reset code for richmond
I am poting this here hopefully it will help someone else. I have a richmond 40 gallon power vent water heater and it was not working. It was flashing 2-3 on the LED. I used this procedure and it started up..
you can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Posted on Apr 13, 2010
SOURCE: turned off the hot water
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Posted on Nov 16, 2010
Why is the reset on my electric hot water heater keeps tripping
Have you tried another breaker? Check the ground wire and natural. And make sure no water around any wires.
Jul 18, 2014 | Whirlpool Water Heaters
Not enough hot water
Some hot water means upper element is good, reset button is pushed in and not tripped, overheating is not issue, wires connected at top of tank are probably good, and unit getting power, but not necessarily full power. Otherwise we have not ruled out anything else.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Check for crossover.
http://waterheatertimer.org/Crossover.html
Check for leaks: turn off all taps and put ear against pipe.
Gene
h
Dec 05, 2013 | Richmond 6E50-2 50-Gallon 4500-Watt...
Heater broke, my Amtrol water heater expansion 80 gal tank, takes hot water from the oil fired furnace, and keeps it hot, However, the tank is set at 140 degrees, but the water coming out if the hot wter...
Hiliary
sounds like the primary coil in side is cracked and is mixing hot water.. with the cold water in tank need to check and replace as necessary
Sep 15, 2013 | Amtrol Water Heaters
6 gal tank puts out only about 2 gal of very hot water. ADoes the same whether on gas or with electric hot rod.
Have you tried it with both (hot rod and Gas ) turned on at same time? Is tank well insulated? (looking from behind tank.)
Does temperature drop off quickly, or gradually? Did it supply hot water better before, or this is first time you really measured it out? Need to keep in mind that as hot goes out the top fitting to hot lines, cold is coming in the bottom fitting and beginning to mix with hot, which obvioulsy will cause hot to gradually become warm as it enters. 2 gallons out hot tap, 2 gals., at bottom of tank, then mixing as it flows in usually equals, about 2 gal or less of warm, then cold again. Get many complaints of only enough for a short shower when they have 6 gal tank. You can try adjusting temperature up a little to see if it helps. Keep an eye on pressure relief valve dripping excessively as well as shut pump off for 20min-30 min, then turn it back on before touching any taps, to see if it cycles at all, indicating a leak in the system. If pump doesn't cycle when turned back on, no leaks.
Jan 27, 2011 | RTO Atwood Water Heater - 6 Gal LP
My water heater thermostat keeps on tripping. I recently changed the temperature settings. I do not know if I increased or decreased the settings. What should I do. Due to this problem I switched on my...
Hi .. if the thermostat is tripping and the safety valve is dripping , that would indicate that the water is being over heated , or the tank is at a low level . Check the thermostst setting, it should be about mid scale. Check the supply valve to be sure that there is a constant supply of cold water. Any thoughts?
May 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
My hot water will not get hot at all. Model SE40M12AA01 Stop getting hot over night. Breaker to heater was tripped, I reset it and still no hot water.
Your upper thermostat on the hot water tank may be shorting out causing your breaker to trip. Remove the outer panel door on the side of the hot water tank and test for power going to the elements. Also check for water as the tank may be leaking and causing the short
Feb 21, 2010 | General Electric GE SmartWater Household...
My ariston electric hot water heater keeps tripping off
Tripping off at the water heater or at the breaker box?
Jan 24, 2010 | Bosch GL4Ti Ariston Pro Ti Electric...
Water Too Hot
needs new thermostat(s) If the whole tank is heating( next time it trips, before using any hot water check the lower tank thru the lower element access(breaker off) If the lower tank is hot-you need a new lower thermostat. if just the upper part of the tank is heating -you need an upper thermostat.
Jan 18, 2010 | RELIANCE ELECTRIC WATER HEATER
What to do if water gets inside hot water tank fluke..and what may happen when the tank fire dont stay lit?when tryinig to lite it
sounds as though you need a "thermo-couple" replacement to make the flame stay on,.......tryin to keep ya in hot water, cracklin joe
Jan 04, 2010 | Emerson InSinkErator C1300 Chrome...
Water Heaters Logo
204 people viewed this question
Top Water Heaters Experts
D. E. Hev
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
