Question about Dryers
Looking to replace gas valve but cant find one with the number the 91043 is there a different part number
    Scholar:
  • 90 Answers
Hi Lloyd,
To properly answer your question, we would need a make and model number from your dryer. They are normally located on the inside edge of the dryer door, printed on a sticker.
I can tell you that may companies will have a new or revised part they manufacture that serves multiple purposes or is an upgraded version of the original. Sometimes you are looking for 91043 and it has changed to 91088 (for example).
If you can get the make and model info, that would help a great deal.
Thanks!!
Posted on Mar 30, 2015
Pilot stays lit but when you turn it to on and then adjust the valve for the burner it all goes out
Brand and type water heater are unknown.
Sounds like FV system has tripped.
Copy following links for troubleshoot resources.
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Look on label on side of tank for Brand and model number.
Then add comment.
Each brand water heater is slightly different, and different by age of water heater as FV systems evolve.
Parts may need to be replaced, including gas control valve.
Nov 26, 2012 | Water Heaters
Will this solve my problem of the pilot going out after the water is hot?
Your thermo coupler may be going out. If the thermo couple does not sense heat it will shut the gas off. This is a safety feature. Once you replace that you should be ok.
Aug 14, 2012 | Camco 08773 Gas Pilot Assembly 9 Inch for...
Hi, We have a Maytag gas range. I believe it's a mgr5710adw the number is wore off and unfortunately we didn't write it down in our manual. Anyway, when using our bake burner sometimes it will...
IF the model number you have listed is what you belive to be correct thepart number for that gas safety valve is 74006427 this link i have included isa picture of it. Does it look EXACTLY like the picture if yes it will work http://www.repairclinic.com/PartDetail/Gas-Valve-Assembly/74006427/895773
GENE
Sep 23, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Broiler does not light....Put in new ignitor; still not working. Checked orfice to make sure its LP and not Natural gas. Its number is #56...Is this correct for LP?
The Jenn-Air Broiler LP broiler orifice is part number: AP4091112. A picture of the part is here: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-orifice--broiler--lp--item-number-ap4091112.aspx . (To me the number looks like 65 to me. The natural gas version is number 47.)
Check the current draw at the igniter. (The meter must be in series with the igniter. I know the bake igniter needs to be above 3.2A.) Other possible causes of the problem are a selector switch problem or the glow bar. (These are things to check if the oven works.)
I hope this helps.
Jul 30, 2011 | Jenn-Air PRG3601P Gas Kitchen Range
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
Have a atwood m#91043 hot water heater.pilot will not stay light.Have changed temocouple.Still the same problem.
If you've replaced thermocouple with new proper one, and you have a good blue flame under it when pilot held on. Try removing the thermocouple where it connects to gas control and spray WD-40 or similar in the hole where the thermocouple was removed from, and take some steel wool (fine) and twist a piece of it small enough to fit in the hole and get to bottom where contact surface is and spin it to clean the contact surface well. Clean it out after with compressed air if possible, then re-install thermocouple and snug it up good and retry it. If that doesn't do it, your going to have to replace the gas control valve.
Mar 03, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I am looking for an on/off/pilot knob for a white rodgers gas valve. Model 35C67-183. Can you help?
Please re- check the part number because this is not a valid part number of White- Rodgers. Maybe this is an OEM part that why we cant see that on our system call the manufacturer of your system they will provide you a replacement.
Nov 30, 2009 | Bakers Pride CO11-G2 Gas Double Oven
Dryers Logo
52 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
