Question about Kobo 6" eReader Touch Edition
Kobo won't turn on
Blank screen and green and blue light
Https://koboproblems.wordpress.com/2013/07/15/how-to-reset-and-factory-reset-your-kobo/comment-page-1/?hc_location=ufi
you have looked how to reset your device
you may loose all settings but im sure it has a cloud backup as most do
good luck
other than this perhaps try to wait till it powers off from very low
bat
i found a few links to forums
google search for links
kobo reset
or factory reset
Posted on Apr 13, 2015
My Kobo Aura HD's comfort light is off and I can't find a way to turn it back on.
On the top of the e-reader, to the left of the on/off slider (looking at the screen) there is a push button on/off switch for the light. Once the light is turned on (and there is a 'star' symbol on the screen, the brightness can be adjusted by touching the 'star' and using your finger to slide the brightness control).
Mar 19, 2015 | Kobo Aura HD E-Reader
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Kobo reader won,t turn off
click on app info and close or use cleaner to close it otherwise skip to another version of kobo reader
Mar 05, 2015 | Tablets & eReaders
Kobo won't turn on, screen blank
This can happen if the battery is very, very flat. Try charging it overnight.
If charging it doesn't help, try using a paper clip in the reset hole to force a factory reset (you may lose any user-installed books).
Mar 01, 2015 | Kobo Glo E-Reader
Kobo ereader fell on floor just have a blank screen
the lcd backlight called a CCFL tube much like the stip lights
has becomes disjointed or has cracked
if the screen survived uncracked then its worth getting it looked at by someone who knows LCDCCFL and where to gain a replacement
Dec 21, 2014 | Kobo 6" eReader Touch Edition
Undefined
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
Hi, i have a kobo arc, and recently it has stopped working. The light stays on, and every time i go on it, it freezes and i cant do a thing with it. not even turn the screen off, or do the volume or turn...
Hold the power and volume button at the same time till u get a box and a tool thing on your screen the by using the volume down go to wipe data press power button to ok then go down to yes with volume down key and press the power button to ok yes then will reset your tablet like when first got it
Mar 05, 2018 | Kobo Arc
Kobo 6" eReader Touch Edition Logo
161 people viewed this question
Top Kobo Tablets & eReaders Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
