Question about Stanley 5000 Pack 2-3/8" x .113 Ring Shank Paper Tape Fram Bostitch
Paper shank , used to fasten papers instead od a staple
Can you show a picture
2 Suggested Answers
  • 384 Answers
SOURCE: stanley bostitch electric staple 02210 won't
You must have bought the Southern model. We work at a little slower pace here.
Posted on Sep 09, 2009
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
How to install paper
Without a manual, look at the picture of the calculator. Mount the paper, with the feed coming forward and over the top of the calculator. Insert the paper (recommend cutting it flush) into the feed slot in the back. Then use the paper advance key to advance the paper through the rollers. Unfortunately the manual is not available from the Staples website. Good Luck,
Mar 02, 2015 | Staples SPL-P100 Printing Calculator
RAPID DUAX CUTTER MECHANISM IS BENT
Easy to dismantel more diffucult to built it back. Thanks to pictures, you can manage to build it back.
This pictures are useful because when you will dismantel the duax, the springs will spring without you had noticed the position of parts.
rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-2.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-4.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-7.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-11.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-16.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-22.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-29.jpg rapid-duax-cutter-mechanism-bent-ppog5cnpznvpbbahtwu3vap3-3-37.jpg
Mar 25, 2013 | Rapid DUAX Heavy Duty Stapler 2-170 Sheet...
Staple shredder
it has to be photo sensor you may need to remove them to clean them. i had to do this before because they were really dirty with oil and paper shavings
Sep 09, 2012 | Office Equipment & Supplies
I tried to staple too many papers together using my Rexel Staple Wizard, now it won't work - any ideas?
open and check the clip from where the pins come out for staple. may be one or two pins are stuck in it.
Dec 15, 2011 | Tools & Hardware - Others
When I use the photo paper it is causing a jam every time I have been using the Staples photo paper - I also need some help / instructions to get the pictures ready. I had the instructions ...
This does not belong in motherboards, because it is a printer/inkjet problem. Make sure the paper and the tray are perfectly level. Some times certain paper isn't accepted into the printer correctly because of the size, so it causes jams. Try using different paper as a test.
Mar 13, 2011 | Computers & Internet
How do I know what paper to get?
Here are the specs of the paper that you need:
Color: White Material Type: Thermal Paper Size: 2-1/4 inches x 85 feet
You can buy this paper HERE
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 05, 2010 | VeriFone Omni 3200 Printer
Paper jammed while printing
took printer back to Staples after HP refused to help. They fixed it and showed me how to do it in the future. Thank you Staples
Mar 22, 2009 | HP PhotoSmart C4280 Laser Printer
Stanley 5000 Pack 2-3/8" x .113 Ring Shank Paper Tape Fram Bostitch Logo
679 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
