Question about Garden
Mower starts and runs fine but when button pulled out to engage blades the engine stops hope you can help Paul
  • Kprime
    Kprime Mar 31, 2015
    Hi Paul Shadbolt, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
  • 1,169 Answers
Most likely cause will be a defective or disconnected operator's seat switch.
Posted on Apr 03, 2015
    Habit-Forming:
  • 101 Answers
Your mower deck maybe seized or the safety switch malfunction check if you can turn your deck by hand if yes then find safety switch for deck hope this helps
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
Why did Craftsman LT2000 stopped moving? Engine starts and blade engages fine.
The transmission drive belt is a separate one from the blade belt. The clutch pedal when released puts tension on the transmission drive belt so it tightens up and drives the gearbox pulley by way of a large spring. Make sure the spring is ok. The belts don't last forever and probably needs replacing looking at the age of the machine. That is a fun job as it is right up under the machine and runs from the engine pulley right back to the top of the transmission. You have to drop the deck right off and I usually find a tree with a large branch and haul the front up with a rope or winch so the mower is vertical. Makes it easier to work on. Drain petrol first though. Hope this helps otherwise get a mower shop to do it for you if you feel it's to much of a task. Good luck.
May 19, 2014 | Craftsman Garden
Blades wont ingage
I would check the belt, the pulleys and the tension of the pulleys. Any of these could be the cause of your issue. Hope this helps!
Jun 08, 2012 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
