Question about Kitchen Ranges
The chimney can extend to just over 1000 mm, can you buy additional ducting to further extend?
  • 4,018 Answers
Needs to be a gap of just 1 meter from the top of the cooker to the hood any lower and you will hit your head or it will suck out the heat has you cook taking longer to cook
Posted on Mar 30, 2015
What size fresh air vent do I need in a boiler room with a gas boiler and gas hot water heater with about 220,000 btu combined
I suggest that you run a duct that is 3 inches larger than the furnace duct . and you should run it down close to the floor and aim it in the direction of the furnace. this will trap warm air above the vent and supply an adequate supply of air for combustion. also make sure you have insulated any pipes in the furnace room that carry water or steam you want heat where you live, not going up the chimney.
Aug 02, 2014 | Water Heaters
When the hot water heater is running water leaks from the chimney. the pipe from the heater to the chimney is dry upon removal. about 3 gals. of water leaks from the chimney with two showers.
If I understand correctly, your Bock gas water heater vent is causing water to leak down into chimney.
This is a very serious concern
Water leaking from water heater flue indicates improper venting.
The hot air gasses from water heater combustion contain water vapor, but the gas should vent out of house before condensate forms on pipes.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#flue
The problem might be caused by a power vented furnace that pushes vent air from furnace down into flue pipe for water heater. As a result, the water heater doesn't vent properly.
There could also be a clog.
Light a match under water heater draft hood and see if smoke from match travels instantly upward.
There are two major concerns.
1) If vent is not working, it means that odorless CO gas is entering home instead of venting outdoors.
CO carbon monoxide is deadly poison.
http://en.wikipedia.org/wiki/CO_poisoning
You can buy CO detector after vent is repaired.
2) Water condensate will eventually rust away vent pipes because of acidic content of the combustion vapor. It can be expensive to replace pipes, and pipes with holes pose risk of CO poisoning.
My suggestion is call a qualified plumber ASAP and explain what you observe.
Plumber will want to inspect the vent pipes, and may want to extend water heater vent pipe up further inside chimney so furnace is not pushing air back into water heater vent.
Plumber may also find blockage somewhere in the vent stack or chimney.
Also post on a professional water heater forum like the Tank to double check anything the plumber says to you. These are the pros.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Dec 25, 2010 | RTO Bock Water Heaters 32E 32 gal 104,000...
I would like to buy the foam for the ducts?
You can purchase the insulation from a local A/C supply house or contractor. They will need to know the size of the pipe (OD diameter). The insulation that is exposed to sunlight can be protected (life extended) by loosely wrapping some duct tape around the pipe to shield it from the UV rays.
Apr 07, 2010 | Heating & Cooling
Can the RC1000 be extended?
I think a swift visit to somewhere like Ebay will show there are differing lengths of shutter release available. Just be a bit wary of where they are shipped from.
Michael
Feb 15, 2010 | Konica Minolta RC-1000 S Remote Control
Takes to long to dry but does get warm
If the airflow is restricted on the intake or exhaust you'll have extended drying times.
Be sure to check the lint filter every time you use your dryer. I know this is obvious but you'd be surprised how many people overlook this and run into bigger problems.
More importantly, disconnect the dryer and slide it forward and then disconnect the 4" exhaust duct from the back of the dryer. Visually inspect the exhaust outlet AND the duct for blockage. Even if it's partially blocked it will cause extended drying times.
Clean out as much as you can. You may need to separate the ductwork to get at all the blockage, but it will be well worth it.
If your ducting is fairly straight, a "Webster" duster (looks like a chimney brush on a telescoping pole) will get the job done.
Run the dryer briefly with the duct unhooked to blow any buildup from the dryer. Then reconnect and blow the rest of the ductwork by running a short cycle with no clothes in the dryer.
You most likely will find better drying times.
Dec 02, 2009 | Whirlpool WED5300S Electric Dryer
No instructions nor fixings with cooker hood. How do we attatch it? How do we get hold of fixings as staff at wicks were useless. Cookerhood EFC90950X zanussi
you will have to place a straight edge on the top on the hood near the exhaust pipe then mesure from the floor to the bottom of the straight edge, that will give you depth then here is the demisons you have to build the box in. And if you don't have the power there you need to get a contrator or do it yourselfer to install it four you.
Price Range:£342 — £2,084 Average Price:£673 —— Colour body Stainless Steel. Body Material Stainless Steel. Colour chimney Stainless Steel. Typology Built-In. Motor location Integrated Motor. Operating Mode Convertible. Connection Rating (W) 225. Voltage (V) 230. Frequency (Hz) 50. Approval certificates IMQ. Length electrical supply cord (cm) 190. Height of the chimney (mm) 815/1970. Height of product, without chimney (mm) 815. Dimensions of the product, with chimney (if exists) (mm) 815-1970X898X490. Dimensions of the packed product...
Aug 21, 2009 | Electrolux Kitchen Ranges
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Kitchen Ranges Logo
338 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
