Question about Home
Water wont heat up in my shower dials dont work either
  • 3,382 Answers
Check your water heater.
Posted on Apr 02, 2015
2 Suggested Answers
  • 29 Answers
SOURCE: Water is not heating at
replace your stems on the mix handle or hot and cold side.may calcium build up
Posted on Sep 18, 2011
Greenstar 30cdi no hot water
It is the shower head or plumbing that has a built in mixer or reducer.
Dec 09, 2013 | Stiebel Eltron CK20E Electric Tankless...
Greenstar 30cdi hot water issue
The problem is not the water heater. The shower has a mixer or a limiter built into the plumbing so that the water wont get hot. It is a safety feature to prevent burns and protect children from scalding.
Dec 09, 2013 | Water Heaters
Hi there, I have a bosch aquastar 125b waterless tank. My problem is that i am not getting hot water at all. The water runs during the shower and it stays warm. HELP!!
This should run two showers at once with no problem. If you have a shut off valve on the cold side of the heater, try closing about halfway. This will slow the water flow and the water will have more time to heat up as it pases through the tank. If you dont have a shut off valve, just cut back the hot water valve on your shower and do not use any cold water. If it gets too hot then turn on a little cold water. The object is to slow the speed of the water going through the tank. Tankless heater take a little getting use to but they work great when you know how to treat them. On my shower I turn the hot all the way on until it gets hot and then add a little cold water to bring the temp down. You may have too much water going through too fast to be able to heat it up to what you need. Try this and see how it works.
Mar 26, 2011 | Bosch AquaStar 2400ES-NG
Good afternoon, We have a 25yr old delta shower faucet and head. both work wonderful but the water is not all that hot- our new hotwater tank is set at 130 degrees. If i need to change the mix do i do it...
You don't change the setting on the faucet or behind the shower wall. You change the mix in the hot water heater itself. New hot water heaters are set at a relatively lower hot-water-setting for liability purposes. To achieve a hotter mix, take the cover plate off the hot water heater. You will see a dial setting that allows you to turn up the heat. Depending on what type of water heater you have, there might be two cover plates (lower and upper). If so, you'll need to adjust both of these.
Feb 26, 2011 | Delta T13420 Chrome Classic Single Handle...
Shower goes boiling hot then freezing
does this happen with any other fixture in your house that almost sounds like an element in a hot water heater.
or remove handle and look for an adjustment dial to temper water and adjust it
Apr 30, 2010 | Home
Dial not working correctly, set on low numbers water comes out at high pressure, set it on high numbers and the water pressure comes out on low pressure ???? why.... the item in question is a Triton Madrid...
It sounds like the numbers are for the temperature indication and the higher the temperature the more slowly the water runs because it takes longer to heat it.
Apr 16, 2010 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Home Logo
54 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
