Question about Miele Washing Machines
Opening door while waterproof fail is showing.
I need to open my door but it is locked and it says watterproof fail. I have emptied water but dont know what else to do. It's a w 1734
  • 24 Answers
Your machine has a round hatch (below left). This hatch gives access to the drain pump and to a yellow lever. If you pull this lever, the door will open mechanically.
Posted on Apr 03, 2015
barkencoa
  • 3463 Answers
SOURCE: Zanussi IZ12 mid program door light comes on.
E40 is a door interlock fault, it is either faulty or the wiring between it and the main board is at fault,
Only way to open door is to remove top cover, and try to force the door open from the inside, if you can see the door latch, try pushing it with a screw driver or something to release it, worst case scenario, is you will have to break the lock to release the door.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
SOURCE: hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Posted on May 20, 2010
torres No9
  • 27 Answers
SOURCE: electrolux EWF1074 front loader ripped rubber
i would get the rubber bellow replaced asap as water will be running onto components causing short circuits
Posted on Jun 25, 2010
AGUSYUSTIARA
  • 116 Answers
SOURCE: im having trouble with my
I've answered these problems through previous posts, you can get answers through my blog archives http://trend2download.blogspot.com/2010/08/problem-with-samsung-wf337aa-front-load.html almost the same problem and its solution .
This answer is: check the hose for water level sensors. The hose from the drum to the sensor, there must be pressure to sensors so the water sensor That Will Be ordered to the electronic circuit to run the washer motor. and water level sensors related to the process, from the wash, rinse and drain / spin. it runs sequentially.
Posted on Aug 07, 2010
  • 5 Answers
SOURCE: need a new door opening handle?? the handle broke
You should be able to order one from Splendide. In the meantime, try using a screw driver to manually push the door release button.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Posted on Sep 24, 2010
HOTPOINT 9526 DOOR STAY LOCKED AFTER FINISHED THE CYCLE
The first thing to check is - does the washing machine still have water inside? If there is obviously still water inside the machine then this is possibly the cause of the door not opening. Drain the machine.
Can't see any water inside
If you can't see any water inside then it may be caused by various faults listed below. Here's a list of the most common causes of a jammed door -
  1. On some machines if the pressure switch doesn't reset to empty it keeps the door lock energized. If this is the case though, unplugging it should allow the door lock to cool down and open after a few minutes.
  2. The water hasn't pumped out properly (or a blockage in the pressure system is holding the pressure switch on) - but only if the washing machine has a pneumatic (air operated) door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
  3. The water has pumped out properly, but the pressure switch hasn't reset due to a faulty pressure switch or blockage in the pressure system - or the water hasn't pumped out properly and the pressure switch hasn't reset because of the water inside. A faulty pressure switch, or blockage of debris inside the pressure chamber bottle could also be trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days).
  4. The door interlock has just jammed
  5. The door catch, handle, or some part of the door catch mechanism is broken and not opening the door
  6. ****** (a device that detects the motion of the drive belt fitted to many older Hotpoint washing machines which "pecks" at the belt when the door handle or button is operated) is broken or has fallen off
Opening a jammed door Do not take the lid off and reach inside the washing machine to try and release the door if the washing machine is still plugged in as you will be electrocuted.
The most common cause of a jammed door is likely to be a faulty door interlock. Sometimes you can release the door from the inside by manipulating the door interlock or forcing the door catch out from it. But they sometimes just have to be broken away from the machine. If you need to do this make sure you -
  1. Unplug it
  2. Break the interlock off from inside the machine, don't force the door or you will just break more parts
Jul 03, 2016 | Hotpoint Washing Machines
Maytag Neptune code fl shows on display
The FL code indicates that the door failed to lock when you closed it. Try opening and closing the washer door again. Make sure that there is nothing in the door area that could block the latch or keep the door ajar. If the error recurs, the latch may be faulty.
If the door is actually locked and giving the FL code, the latch has a problem. You can try power-cycling the washer (unplug for a while) or setting the washer to pump the water out. If these steps don't help, you need to order a replacement latch assembly. Depending on your washer model, you may have a manual pull cord to unlock the door. Look under the bleach and fabric softener compartments after opening the dispenser..
I hope this helps. If your washer is under warranty, contact Maytag. Otherwise post a comment with the model number of your machine for a source for a replacement latch assembly.
Oct 27, 2014 | Washing Machines
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Power went out door locked
Instructions
<:section abp="1260">
    • 1 Unplug your Whirlpool Duet washer from the wall receptacle.
    • 2 Remove the three screws along the bottom front of the washer. Pull the bottom panel from the washer, opening the front of the washer.
    • 3 Reach your arm up through the opening to locate the door latch assemble inside the body of the washer. Grasp the tear-shaped tab with your fingers. Gently pull down on the tab until you hear a click. Pull on the Duet door to open it.
    • 4 Look inside the latch opening in the body of the washer for foreign material. Remove it from the switch with tweezers or needle-nose pliers. Look for any pieces of broken plastic that could indicate the door lock mechanism is broken and needs replacing.
    • 5 Shut the door on the washer and plug it into the wall receptacle. Confirm that the door remains unlocked. Unplug the washer and release the lock on the washer door as before if it fails to remain unlocked.
    • 6 Unplug the Duet washer from the receptacle. Pull the washer from the wall so you can access the rear of the washer.
    • 7 Remove the three screws from the top back of the Duet washer. Lift the top off the washer. Find the central control unit, or CCU, at the back right of the washing machine.
    • 8 Check that all the wiring harnesses plug securely into the CCU. The wiring harness for the door-lock solenoids is the sixth harness from the left of the CCU. The wiring harness for the door-lock main switches is the only black harness connected to the CCU.
    • 9 Remove the round retainer holding the rubber boot gasket from the Duet washer door opening by inserting a flat-head screwdriver beneath the spring on the retainer. Pull forward on the retainer spring to release it from the boot gasket.
    • 10 Pull the rubber boot gasket away from the opening at the switch location to access the door switch assembly. Check the wiring harness on the switch assembly to make sure it is engaged. Snap the gasket back in place, and replace the retainer on the washer.
    • 11 Plug the Duet washer into the wall receptacle. Select a washing cycle and press start. Listen for the door lock to engage. Turn the washer off and listen for the door lock to disengage, or wait 30 seconds and try to open the washer door.
    • 12 Unplug the washer from the wall receptacle. Pull the wiring harness for the door-lock solenoids from the CCU. Number the sets of wires attached to the wiring harness as 3, 2 and 1, from left to right.
    • 13 Set an electrical multimeter to "Ohm X1K." Insert one probe from the multimeter into opening number 3, along with the wire. Insert the remaining probe into opening number 2, along with the wires. The multimeter should read 60 ohms. Leave the probe in opening number 3, and move the remaining probe to opening number 1. The multimeter should read 60 ohms in this position as well. Should you receive any other reading, replace the wiring harness.
    • 14 Reconnect the wiring harness for the door-lock solenoids into the CCU. Plug the Duet washing machine into the wall receptacle. Select a wash cycle on the duet, then press start. Listen for the door lock to engage and immediately unplug the washer from the wall.
    • 15 Leave the wiring harness for the door-lock main switches plugged into the CCU. Number the wires in the harness 5, 4, 2 and 1, from left to right. The middle opening on the wiring harness is empty, so there isn't a third wire.
    • 16 Set the dial on the electrical multimeter to "Ohms X1K." Insert one probe into the opening next to wire 5, and insert the remaining probe into the opening next to wire 4. The meter should read zero ohms.
    • 17 Insert one probe into the opening next to wire number 2, and insert the remaining probe into the opening next to wire 1. The meter should read zero ohms. Replace the wiring harness should you receive any other reading.
Found this on the web . Hope this helps
Mar 30, 2014 | Whirlpool Duet WFW9750WW White Front Load...
Dont work rear door locks
Your Tempo is equipped with early child-proof rear door locks...(cannot open from the inside when locked) Open the doors from the outside and look near the door catch for a small switch that moves back and forth...if still labeled it should show "Lock...Unlock" marks...leave on unlock for normal opening from inside. Hope this helps.
Jan 21, 2013 | 1992 Ford Tempo
My maytag neptune MAH8700AWW shows an error code OE and the door is locked, how do I fix it?
Opening a locked door , click for a visual demo: Door locked#
It is possible that the actuator to the lock has failed and so is not releasing or there is a error on the control panel.
Jul 05, 2012 | Maytag Washing Machines
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Hi, I have a zanussi wwashing machine model= ghg1200apm. The door won't open. I plugged out the machine after the wash and when i plugged it in again, the door wont open. Can you help me?
Hi.
The door does not open because there is water inside the machine. To open the door you need to empty the tub first.
To empty the tub disconnect power, open the door at the bottom of the machine's front side, unscrew the drain filter cap and collect water using a container.
Usually that is enough to allow the door to open. If the door does not get released, try running a cycle again.
If still no luck, then the door is locked either because the pressure switch detecting water level is clogged with soap or because the power surge has damaged some component. In that case the machine must be partially disassembled to reach the back of the door opening mechanism. The door latch is reachable either from drain filter access or from top of the appliance.
Emptying water through the drain filter and/or restarting a cycle usually is enough to release the door lock.
Regards.
Ginko
Aug 19, 2011 | Zanussi ZWF12070 Front Load Washer
I just posted this answer on an old Dec. 07 posting.
In case you can't find it, try opening the DC IN / USB port cover just to the right of the dial. This breaks the waterproof seal and allows the camera to open. I think the design flaw is an inadequate volume differential in the water sealed cavity to properly account for the change in volume caused by the lens opening / retracting. The USB cover can be closed once the lens is open to restore the waterproof characteristics.
Mar 24, 2008 | Olympus Stylus 710 Digital Camera
Miele G575 slow and insufficient water fill
The unit has a double valve system, the waterproof, it could be that one of the valves is not opening fully. They can break down over time. This would mean you need a new one. This should fix the problem.
Open the door once the wash has started and check the water level. It could be that it is siphoning out half way through the wash. Make sure your drain hose is secured up properly.
If when you open the wash and there is not enough water, it is most likely the waterproof, as I stated before.
cheers.
Sgt 48
Oct 30, 2007 | Miele 24 in. G656SCi Plus SS Built-in...
Washing Machines Logo
35 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
