Question about Cell Phones
Does not charge phone! - Cell Phones
    Problem Solver:
  • 5 Answers
The phone is messed up or a wire fried in the charger.
Posted on Mar 30, 2015
Does not charge
Have you use another similar charger to charge the phone to see if it will charge? If you have and yet the phone did not charge, the problem could be from the phone charging port, you will need to replace the phone charging port befoire the phone can charge.
If the charging port i replace, the phone will charge.
Take care.
Aug 25, 2010 | Nokia N900 Smartphone
1600 not chargieg
If your phone is not charging, try use a similar charger to charge to see if it is charger problem, if the similar charger did not charge your phone, it means the problem is the charging port on your phone.
The charging port of your phone is bad and will need to be replace. Replace the charging port on your phone to solve the problem of your phone not charging.
Once the charging port is replaced, the not charging problem with your phone solve.
Take care.
Jul 23, 2010 | Nokia 1600 Cellular Phone
My phone is not charging
Take care.
Jul 23, 2010 | Sony Ericsson Walkman® W880i Cellular...
Phone not charging,display says error stop charging
If your phone is not charging and the screen read error stop charging, you can look at the problem from angles, firstly, i suggest you try get a similar charger to charge the phone and see if it will charge it, if it does, it means the charger your charger is the problem and will need to be replace.
But, if after trying to charge with a similar charger and the screen of your phone still reads error stop charging, then, the problem is the charging port of your phone. In this case, you will need to replace the charging port of your phone, in order for your phone to charge.
Check either of the two stated above to solve the problem with your phone.
Take care.
Jul 17, 2010 | Sony Ericsson Z610i Cellular Phone
Phone won't charge or hold a charge - tried 3 different chargers and a new battery. Cleaned all connection points with alcohol. LG Vue
The problem with the phone is the charging port since you have use different charger and you have even change the battery and yet not still charging. it means the charging port of your phone is the problem.
All you need to do i to replace the charging port on your phone and you will see that your phone will charge.
Replace the charging port on your phone and your phone will start to charge, just change the charging and the problem is solved.
Take care.
Jun 02, 2010 | LG Vu CU920 Cellular Phone
Samsung SGH D807 Charging Problem and no screen display
Have you try to use another similar charger to charge your phone to see if it ill charge? because it could be that your charger is bad,. But if you have done that and it is same thing, it means the charging port of your phone is malfunctioning, that is why you have to use repetitive effort before it can charge.
Your battery is not charge due to the bad charging port of your phone, so your phone battery can not hold charge.
To resolve 1 and 2 problem of your phone, all you need to do is to change the charging port of your phone in other for your phone battery to charge and for your battery to charge.
Replace the charging port as said and you will see that your phone battery will charge.
For your screen, is it that the entire screen is black that you cannot see anything, not even text or see names from your contact? if it is, what you need to do is to change the flex on the the screen of your phone and you will see that your screen will display as you want it.
Take care.
May 04, 2010 | Samsung SGH-d807 Cellular Phone
Not charging
Have you try to use another charger to charge it to see if it will charge, because it could be that your charger is bad, if you have and it did not charge, no problem.
It means the charging port of your phone is bad that is why your phone is not charging.
All you need to do is to change the charging port of your phone, changing the charging port of your phone will make your phone charge because the one there at the moment is bad.
Change the charging port and you will see that your phone will charge.
Take care.
May 02, 2010 | Nokia 2600
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
My phone wont charge
Try to remove the battery and put it in a similar phone, charge with your charger, if it charges, it means the charging port of your phone is bad and will need to be replaced.
But if the charger did not charge your phone, it means the charger is the problem.
You can also use another charger to charge your phone to see if it will charge it, if it does not, it means the problem with your phone is the charging port.
Replace it and your phone will charge.
Take care.
Apr 21, 2010 | Motorola Mobility BT50 Cellphone Battery
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
