Question about Retail Supplies
My POS printer prints the currency after the number left side. how do I change to print on the right side?
Xprinter POS X58
  • 591 Answers
It is not the printer, On your system go to print options and select ENGLISH or USA. It is possible that it is set on Arabia. good luck
Posted on May 02, 2015
2 Suggested Answers
edward16
  • 59 Answers
SOURCE: printer only printing on part of paper When I
check your paper rollerand gear first, it is attached to the paper cover. if the roller and gear is good condition your thermal printer maybe bad or dirty. you can try cleaning the thermal head. get a piece of thermal paper fold it. rob the paper on to the thermal head. do it 2 or 3 times with a clean piece of paper. then try printing again. if if doesn't work. call (775)358-2922 look for randy and maybe we cal help. thanks
Posted on Oct 04, 2011
Scx4623f problem with printing right side dark and left side deem
Try to remove toner cartridge and shake, plug in and make a self test print. if not work, you need to change new toner cartridge to make sure that the problem is not with printer itself.
Feb 11, 2014 | Samsung SCX4623F AllInOne Laser Printer
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Casio pcr-272 has stopped printing. paper is correct type and loaded correctly, ink is fine. only prints about 4 characters on the right side of the tape
give it a hard reset. so unplug and wait 30 seconds and try again if this doesn't work then it could be a software related error. unfortunately you would have to do more research
Jan 14, 2014 | Casio Parts Cash Register PC Desktop
Casio register prints mu in front of all values
You need to program $ sign on currency. Go to printing options and scroll to currency press enter and select $
Jun 29, 2013 | Casio PCR-T48S Cash Register
Landscape printing on t2340
printers>properties>general tab>printing preferences change print mode to landscape from portrait..........
Jan 23, 2013 | Tally T2340/24 Matrix Printer
Only printing left side receipt- any ideas?
You can change the printer roller in your VX510 then you will get the proper print from your Vx510.
psoftware109@gmail.com
Nov 26, 2011 | VeriFone VX510
Samsung 1640 printing problem
A number of things! First did you ever clean out the paper path? Run out and buy paper path cleaner and run it 10 times. Try printing again and see if it corrects the problem. If it still acts like that, then you would need to change out the toner (if supected of defects or if empty) or change out the led inside the printer which you would need a repair manual to disngage and replace it.
Mar 05, 2010 | Samsung CLP 315 Laser Printer
I print on labels and the print is too high. How can I lower Print on page?
hold go and return power on the printer until in the screen you see it start to veify ram then release. this will bring the printer up to registration hit select there will be 4 settings showing right left top and bottom. use the select button to move from setting to setting if the print is to high minus from the number showing in the top position make the same number change to the bottom setting untill the print is in the right position. remember or make note of these changes if the print gets further away reverse your changes
Nov 04, 2009 | Lexmark T640 Laser Printer
EPSON POS PRINTER does not print receipt
Try to clear your printer's queues up messages of all print commands that failed to print. See, what happens it when you send a document to printer, if it fails to print, and you send another, it queues up behind the first that failed to print. So instead of printing the second document it prints what you are seing, special characters etc.
Solution:
Go to start/priners and faxes and right click on your printer and select open. You will all the documents for print so far queued up. select and delete them. Restart your system and the printing should be Ok.
Sep 17, 2009 | POS X POS-X XR210 Thermal Printer
Epson TM-T88III Won't print cents column on Z-out store report
Could be the driver or it could be a setting needs to be changed in the POS program.
I would check with whoever made your POS program to see if they have any suggestions.
Jun 12, 2008 | Epson TM-T88III (C420863)
Retail Supplies Logo
102 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Are you a Retail Supply Expert? Answer questions, earn points and help others
