Question about Samsung Dishwashers
Samsung DW7933LRASR won't turn on and water still inside. The door closes fine but can't get power. What to do?
  • Samsung Master
  • 473 Answers
Most dishwashers have interlock switches attached to the door switch. Door could be closing and latching well but if switch is bad or wiring loose the dishwasher will not start. It thinks the door is still open.
Posted on Mar 31, 2015
Samsung model number DW7933LRASR wont start.. clean button is staying lit up....
After the dishwasher has completed all portions of a cycle, all other indicator lights are turned off and the "Clean" light is illuminated for 10 minutes. If you open the door when the "Clean" light is illuminated, it turns off immediately. If this is not happening for you the unit may require service.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Jan 12, 2015 | Samsung Dishwashers
How do I fix a over level water error for my Samsung dishwasher
That's usually caused by a bad case-break (or case-brake) assembly (located on the left side of your dishwasher.
Oct 20, 2014 | Samsung Dishwashers
I have a samsung dishwasher that has no power at all,reset the breakers, still no power. Purchased just 1 year and 5 months ago. Any suggestions?
Check the wiring in the junction box of your dishwasher. If that's okay, then you probably have a bad (burned-out) control module located inside the door.
Oct 14, 2014 | Samsung 24 In. Stainless Steel Dishwasher...
How do I troubleshoot my Dishwasher that will not run. No lights on at all.
Make sure you have power with ground connection and close the front lid / door. Properly. This didnt help then possibility of faulty board.
Jul 14, 2014 | Samsung DW7933LRASR New 24 Dishwasher
Samsung dishwasher flashing heavy light
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Apr 03, 2014 | Samsung DW7933LRAWW 24" Tall Tub Built-In...
Brand new Samsung Dishwasher DW7933LRA Flashing light "HEAVY" and will not start
Apr 03, 2014 | Samsung DMT400RHS Builtin Dishwasher
Samsung mhx-w300 won`t turn on
you must press the reset button inside the SD card door. Remove the flash card first. this should allow you to power the camera on.
Feb 04, 2014 | Samsung HMX-W300
I have a front loading Bosch washing machine and it was working fine on Friday. On Saturday morning I went to take a load of clothes out and the door won't open - I am getting an E13 signal. My...
Hi!
The door lock uses electrical power to keep the door closed. Unplug the machine from electrical power and the lock will be released in a couple of minutes. Please be sure not to flood the room if the water level inside is above the door level.
Regarding the E13 error itself, it means too long draining time, and it can be caused commonly by something stuck in the drain filter. To get to this filter and clean it, you have to look at the lower part of the machine and remove the circular panel, then insert a little screwdriver into the hole and twist , the acces pannel will get open. Now twist the handle of the filter and pull it out. Now it can be cleaned. CAUTION: opening the filter will cause all water inside the machine to get out, so have some towels handy to avoid water to spread all over the floor.
Hope it helped,
Bogdan
Aug 28, 2011 | Bosch Washing Machines
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung-specific parts here: http://www.samsungparts.com/search/search.asp
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
Dishwashers Logo
356 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
