Question about Mazda Vehicle Parts & Accessories
What are the programming for a 2012 Mazda6 key fob? Is there a separate "diagnostic" procedure I can use to verify that the car's system is working before I spend $100 on a new fob?
j_del
  • 1586 Answers
SOURCE: central locking system stopped working
If the A6 layout for the modules is the same as my A4, the lock pump is in the rear corner of the car, on the passenger side. In the trunk, pull up the carpeting behind the passenger rear wheel, and tucked down in there is the pump assembly. They're known to go bad and it's a pretty likely cause for your problem, provided your fuses are not blown.
Posted on Aug 08, 2008
raygin
  • 322 Answers
SOURCE: 2003 Jaguar S-Type, programming a key fob
The switchblade key would need to be compatable with your ignition switch barrel. Only normally available from jag dealers who check the Jag owners register before supplying you a replacement.
The older type seperate fobs could be programmed by switching the ignition on and off 8 times (allowing all functions to settle) and on the 9th switch on - press a button on each fob and then switch off. to test use a good fob to lock the car then try the reprogammed fob to unlock/lock. Sometimes this works first time - sometimes needs a couple of tries.
Posted on Apr 03, 2009
baccardo
  • 150 Answers
SOURCE: Programming a key fob
you will need the dealership diagnostic tool to program the remote
Posted on Apr 24, 2009
Molson02536
  • 3854 Answers
SOURCE: How do I reset a Key Fob for my 2006 Grand Prix
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps: Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation
Posted on Nov 13, 2009
  • 262 Answers
SOURCE: 2001 Santa Fe Key fob Programming
change the batteries then start the car and close it and press the key it should work
Posted on Nov 15, 2009
My 2012 kia optima Fob died i replaced the battery but it still wont work unless i put it in the glovebox just to start the car the buttons on the fob doesnt work i only had the car for 2 months.
There is a possibility that your key fob might lost the programming. I suggest that you re-program your key fob, follow the next steps to re-program it.
Instructions
    • 1 Sit in the vehicle and close all the doors. Insert the key into the ignition.
    • 2 Turn the key to the "Off" position then to the "On" position. Repeat this until the door locks cycle to indicate that the programming mode is activated. End with the ignition key in the "On" position.
    • 3 Press the "Unlock" or "Lock" button on the programmable remote. Listen for the doors to lock or unlock to verify successful programming.
    • 4 Turn the ignition key to the "Off" position. Listen for the door locks to cycle to indicate that you have exited the programming mode.
    • 5 Repeat the above steps to add any additional remotes.
Read more : http://www.ehow.com/how_7446180_program-key-fob-kia-optima.html
May 31, 2015 | Kia Optima Cars & Trucks
Program new key fob for Cadillac cts 2003
There are several methods of doing this - but your 2003 requires that you either go to the dealer for them to add a FOB with special equipment (ask if they'll do it for free - can't hurt). If you have time to kill, you can do it yourself with Method 3 as described and found at:
Key Fob Reprogramming General Cadillac Forums
Method 3 - Key Fob Auto Learn
This procedure will first erase all known key fobs. The procedure will then program a single or multiple key fobs. Method 3 is a series of three 10-minute key cycles, for a total of 30 minutes. This procedure requires that you have a replacement key fob and the vehicle mechanical key.
Important: All previously programmed key fobs will be erased upon completion of the 30-minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known good key fobs in the vicinity of the vehicle when programming with Method 3. If the RCDLR recognizes a known good key fob during Method 3 programming, the programming mode will resort to Method 1.
The vehicle must be OFF.
Place the replacement key fob in the console pocket with the buttons facing forward.
Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
The DIC will display a message: OFF/ACC TO LEARN.
Press the OFF/ACC portion of the ignition button.
The DIC will display a message: WAIT 10 MINUTES, then it will count down from 10 to 0, one minute at a time.
When the counter reaches 0, DIC will display OFF/ACC TO LEARN.
Repeat steps 5-7 two more times, for a total of 30 minutes.
A beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased. When fob 1 is programmed a beep will be heard and the DIC will display a message: READY FOR FOB 2.
Additional key fobs can be programmed by taking fob 1 out of the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode.
If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
Operate the active portion of each key fob in order to finalize the programming sequence and verify correct system operation.
Feb 25, 2015 | 2003 Cadillac CTS
How do I program a transponder key for Mazda6
You will have to take the vehicle to a Mazda agent and ask them to program a transponder key for your car. Every key is specially programmed for a particular vehicle according to its VIN number.
Oct 21, 2014 | 2009 Mazda MAZDA6
Saab experts
May be keyfob needs reprogramming.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There are few much related troubleshooting links mentioned below for remote key fob reprogramming. I suggest you to go through the list and click the link below to go through its details and procedure: -------
Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2009 Toyota Highlander: Smart Key Not getting Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Peugeot 206 key fob
Try with brand new key fob battery and see.If that helps.
Otherwise May be keyfob needs to be reprogrammed.
KEYFOB PROGRAMMING
Thanks.
Nov 28, 2012 | Peugeot Cars & Trucks
How program the key remot
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting Detected? http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob? http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
----------- Pin that holds the flick key part to the key fob? http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar? http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
----------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
Mitsubishi Car Key Not getting detected after replacing ECM http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
----------- Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not Working? http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
----------- Chevrolet Malibu: Key Stuck in ON position? http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
----------- Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not release? http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
Nov 23, 2012 | 2006 Toyota Tacoma
Replaced chip on key on 91 DTS and car lost all power while driving. It shut down and nothing works.
There are 4 methods for programming key fobs. Up to 4 key fobs may be programmed to the remote control door lock receiver (RCDLR). Each programmed key fob is given a position of #1-#4 in the RCDLR memory.
Method 1 - Key Fob Quick Learn This procedure will add key fobs. Fobs will be numbered in sequence based on when they are programmed; if 2 fobs are currently programmed to the RCDLR, a fob programmed using this method will be numbered as Fob 3. This procedure requires that you have a known good key fob, a replacement key fob, and the vehicles mechanical key.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
Place a known key fob within the interior of the vehicle.
The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4).
Place the replacement key fob in the console fob pocket with the buttons facing forward.
A beep will occur and the DIC will display: READY FOR FOB X (X = fob 3 or 4) or MAX FOBS LEARNED.
If programming additional key fobs, repeat steps 5 and 6, or press the OFF/ACC portion of the ignition switch to exit programming mode.
Method 2 - Key Fob Slot Programming
This procedure will add or replace a key fob. Method 2 allows you to choose which location (slot) the unprogrammed fob will be learned to. If you are replacing a key fob, this method will erase the previously known key fob programmed to that particular slot. This procedure requires that you have a known good key fob, a replacement key fob, the vehicle mechanical key, and a scan tool.
Important: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the DIC will display MAX FOBS LEARNED and the programming procedure will exit. Method 4 must be used in this instance.
Install a scan tool.
Use the scan tool, to access the following:
• Vehicle Control Systems
• Computer/Integrating Systems
• Module Replacement/Setup
• RCDLR
• Program Key Fobs
Select Fob X (X = 1, 2, 3, or 4) on the scan tool. This will be the slot you wish to program to.
Place the replacement key fob in the console pocket with the buttons facing forward. A beep will occur indicating programming completion. The previously known fob is now erased.
If programming additional key fobs, repeat steps 4-8, or press the OFF/ACC portion of the ignition switch to exit programming.
Remove the scan tool.
Method 4 - Service Programming System Fob Programming
This procedure is a 10-minute relearn procedure using the Techline Terminal with SPS software. Once the 10-minute timer has expired, the fobs can be programmed similar to Method 2 using slot programming. A scan tool, Techline Terminal, and a replacement key fob are required to perform this procedure.
Place the vehicle in the Vehicle On, Engine Off mode.
Connect a scan tool to the vehicle.
Insure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
Turn the vehicle OFF.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10 minute relearn procedure.
When the 10 minute relearn procedure has completed, use the scan tool to access the following:
• RCDLR
• Program Key Fobs
If programming additional key fobs, repeat steps 12-13, or press the OFF/ACC portion of the ignition switch to exit programming.
Oct 26, 2011 | 2006 Cadillac DTS
Central locking on mk 5 golf works fine with key in lock and from inside car using switch but only unlocks drivers side using key fob. any answers?
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Polo: Press key unlock button for approximately 1 second. Golf/Bora: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction.
How - Polo
Keys can only be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed.
How - Golf/Bora
98MY
How - Golf/Bora 99MY
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Keys can also be programmed using diagnostic equipment.
Mar 07, 2010 | 2001 Volkswagen Golf
Key fobs not working i have changed the battries on both
: If a double audible warning sounds during the programming procedure a system malfunction has occurred. Repeat programming procedure.
Obtain all keys fitted with remote control. Open driver's door. Operate headlamp high/low beam switch to flash high beam position and hold. Insert key into ignition switch, turn to ACC position. Ensure system LED flashes once and an audible warning sounds. Operate headlamp high/low beam switch to flash high beam position 5 times. Ensure system LED flashes once and an audible warning sounds. Programming mode activated: Press and release lock or unlock button on first key. Ensure system LED flashes once and an audible warning sounds to indicate correct programming. Repeat programming procedure for remaining keys. Switch ignition OFF and remove key. Close driver's door. Check operation of keys. Keys can also be programmed using diagnostic equipment
Jan 31, 2010 | 2002 Jaguar X-Type
Programming a keyless entry remote
Key Fob Auto Learn
Do not place any known good key fobs in the vicinity of the vehicle when programming.
Good luck and hope this help's keep me posted, there are 3 other methods and the 5th method is a tech 2 scan tool that the dealer uses but this should work on your year of cadillac.
Jul 01, 2009 | 2003 Cadillac Deville
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
JOHN LAPIER
Gary Nitowski
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
