Question about Dodge 2007 Grand Caravan
I have 2007 3.3dodge grand caravan idles great give it gas sounds like its starving and no power relaxed map sensor any ideas
  • Dodge Master
  • 3,382 Answers
Monitor fuel pressure
Posted on Apr 03, 2015
SOURCE: idles fine but stalls when i give it gas?
Hi jkeefer,
I'd suggest you check the air flow sensor
Regards Johngee10
Posted on Sep 08, 2008
  • 2920 Answers
SOURCE: my 1990 chevrolet lumina 3.1 eurosport dies when i give it gas.
it sounds like a timing issue
Posted on Jan 19, 2009
ourhowse
  • 2007 Answers
SOURCE: car idles rough and stalls
Have you ever changed the fuel filter? If it's not that, and it's not a vacuum leak, it is probably your idle air control valve.
Posted on May 08, 2009
  • 14036 Answers
SOURCE: 2005 dodge grand caravan getting code p0406
3.3 engines has the egr valve with transducer.you have to replace the whole unit. code p0406 what its trying to tell you your egr valve circuit is short to ground.it has failed .
Posted on Jul 04, 2009
SOURCE: 1991 s15 4.3 TBI jimmy will not idle
I had this problem also and it turned out to be egr solenoid
Posted on Feb 20, 2010
1996 Grand Caravan Backfiring through intake
sounds like you didn't get the wires on the correct plugs .
Mar 03, 2014 | Cars & Trucks
2000 Grand Caravan starving for fuel
replace fuel filter and clean the MAF sensor
Jun 10, 2013 | 2000 Dodge Grand Caravan
Starves for fuel on acceleration and wont idle right
Gas problem, likely. Have your fuel pressure tested. Fuel pump or filter may be the problem.
Dec 31, 2012 | 1997 Dodge Grand Caravan
2001 Grand Caravan will not run
code p 0106 refers to manifold absolute pressure (MAP)sensor or barometric pressure (BARO ) sensor---range /performance problem====causes ---intake / exhaust leak---wiring --- MAP pr BARO sensor problems
intake leaks( vacuum leaks)can be purge vent leaks, transmission actuator leaks , dash vent controls vacuum leaks
exhaust could be cracked flex section of the exhaust pipe at the manifold
Mar 05, 2017 | 2001 Dodge Grand Caravan
Just changed map sensor fuel filter idle control valve and when you press the gas it hesitates like its bn starved think its a bad injector all the vac lines are connected checked relays still having probs...
check the fuel pressure and volume with a gage and check to specs.it could be a bad tps sensor.if it was a bad injector it would run rough and not feel like its starving for gas.it could be that all the injectors are dirty and need to be cleaned or if too dirty replaced.
Jun 21, 2011 | Chevrolet Silverado 1500 Cars & Trucks
My 1996 grand caravan shows a PO106 code. I changed the MAP sensor but it still throws a PO106 CODE and idles at 1300 RPM. What sensor do I check next ?
make sure that you have a 5 volt reference at the sensor. back probe the black with a blue tracer with a dvm (digital volt ohm meter)with the senor disconnected with the key on. Your idle problem could be caused by a vacuum problem this could also give you a map sensor trouble code
Jul 10, 2009 | 1996 Dodge Caravan
Stalling at lower speeds
either fuel filter stoped up , air filter, the egr valve stuck open ,or a vaccum leak
Jul 16, 2008 | 1996 Dodge Grand Caravan
Dodge 2007 Grand Caravan Logo
292 people viewed this question
Top Dodge Audio Players & Recorders Experts
NOEL
NOEL
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
