Question about Music
I'm trying to burn a CD but the 'CD full' info comes up. This is probably because I have recorded more than 80 minutes on the system. Any idea how I can get round this, for instance by splitting the recording into two? The manual just says 'reduce the amount of data to be written' but does not explain how. Thanks.
    Sergeant:
    Novelist:
  • Music Expert
  • 126 Answers
Yes you can splitting recording in two.
What kind of data that you want to burn?
If miscellaneous,you can compress before burning.
If mp3 songs or video files,a little lower the bit-rate.
Blank CD is 80minutes/703MB.
It is recommended to leave 4-10MB to be used by the system.
Posted on Sep 02, 2015
CRTN
  • 716 Answers
SOURCE: I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Posted on Jan 05, 2009
SOURCE: Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Posted on Jan 20, 2010
  • 5603 Answers
SOURCE: my Fostex mr8 hdd "full"
If you can reformat the drive after dumping out anything you want saved MIGHT fix the problem...
The unit MAY not be able to tolerate fragmenting when you delete a snippet here and there... It may require large blocks of contiguous space.
Posted on Feb 27, 2010
Testimonial: "thanks mate, that was it"
Ironfist109
  • 3018 Answers
SOURCE: sorry for my terrible english
  • So if I understand you right, and I think I do. You are putting the looping on so you can record your own tract but for some reason the amount of time you think you have recorded is not being reflected in listening to the playback correct?
  • When you push play then the beat will begin to play. It will continue to play until you stop it. Now while the beat is playing you want to hit "record" to record anything you want to have recorded. If you hit the record button again then this will pause what you are recording BUT you will continue to hear the loop. This allows you to choose different parts of the loop to lay a chop down on. So in other words if you press play (this allows the selected loop to being) then you press record to record everything. If you press record again while the loop is playing this will stop ALL recording but you will still hear the selected loop playing. You have to press record again to continue recording.
  • Also remember that if you have somehow reached 24 minutes of recording then you have to remove it to make room for more recording. You do this by hitting the "undu" button.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 03, 2011
  • 5603 Answers
SOURCE: I'm trying to burn a
"it never works"... this is NOT enough information for us. You are not telling us how the CD is tested. If you are testing it in a boombox type player, that is not a test. First thing is to look at the bottom of the CD to see if you can detect written tracks... with right lighting you can tell if it has been burned. REMEMBER that CD's, unlike phonograph records, are written from the middle outward. Many consumer players have trouble playing CD's that are written but not "finalized". If you CAN see written area (compare to unburned CD) then likely the burning is taking place, and the problem is the format is either not complete or incompatible with your player. Try reading the disk in your computer. Also you might want to visit the forums for the Boss/Roland workstations at VSPLANET.com.
Posted on Aug 19, 2011
IVE TRIED MAKING A CD OF A SONG JUST RECORDED A IT WONT BURN
Try transferring the song into a playlist on itunes, then click the burn cd button. If this doesn't work try a different cd, the one you are using might already be used or the incorrect format.
Aug 26, 2011 | Music
I'm trying to burn a song to a CD-R using a Boss BR 1180 but every time it completes, there's no song on the CD. I record, bounce, record on 9/10, then try to write to CD and it never works.
Aug 19, 2011 | Boss Micro BR Digital Recorder
My roland br 1600 cd rec.studio is just over a year old.I have 4 songs currently on it (80 gb) and it says HD full.It cant be full ....I cant work because of this error...
Yep... the hard drive is 80GB... so if you have 80GB of songs (not hard to do) it is full. Purge some off to make space. Those must be either long songs or have a lot of high frequency stuff using a lot of data to store them or a lot of tracks per song. For stereo recording two tracks using computer I chew up about 1 GB per hour. If you have armed more tracks this could really jump up... and these units may not be as efficient as the new software PC DAW's. I would recommend purging existing songs to a safe media and then reformatting/initializing the drive in the unit.
Aug 18, 2011 | Roland Boss BR900CD Digital Recording...
I had recorded 16 complete songs of my own on a 512 mb sandisk sd card. When the card was almost full i removed it and recorded other new songs on another card. when i re-introduced the first card it had...
A very important thing when using these recording devices is to PROPERLY close the media. I would not panic at this point. Search for a forum regarding the Boss Micro BR and ask there as somebody may be able to help you recover the data. Read up on your manual about shutdown. I have Tascam recorders and I prefer to stop the recording and then when it is done I turn power off before removing the media. You may have to use a special procedure when introducing the nearly full card... even forcing it to load.
Apr 27, 2011 | Boss Micro BR Digital Recorder
Lexicon omega usb board burn in two places part[80-0112-b]digital B D
One can burn up equipment if you have powered parts of it from different sources...such as connecting things together that get their power from different receptacles. Ground bounce and fault currents of defective equipment can burn up things. You will probably have to send your unit back to the factory for repair.
Jan 08, 2011 | Lexicon Omega Desktop Recording Studio
Is there a good tutorial avail? I lost all my music trying to create a cd without finalizing or mastering!!!! Panic took over and i rushed to undo without fully understanding what i did exactly. No...
You can download a manual from the tascam site for this model. as long as you pre-named your songs, they should show in the menu without mastering. You cannot burn any songs without mastering your songs first, however. They will not appear in the create cd section for this very reason.
Record, master,burn.
Jan 05, 2011 | Tascam 2488mkii 24 Track Recording...
I have a behringer xenyx 1204usb mixer with a mxl 990 mic and i have problems with static. thats all i have hooked to the mixer so i dont think its a conflict. i have tried recording in audition, pro...
Yep ! First thing is to eliminate any processing resource "hogs" that **** respources and can cause buffer overruns. Eliminate Antivirus, antispyware, and network communication and wireless network programs running in the background while recording.
Next make sure that ALL equipment is powered from the same receptacle or power source. In your case that should be the mixer and the PC.
Next remember that the condenser mic picks up everything... I have 5 of those mics and seemingly noise free environments turn out to have little things that generate fast rising pulses that you don't notice till they are recorded.
Lastly, the air here is very dry and plain old static electricity is rampart... Lady shuffling her feet was sending pulses through the mic cable at our church. They are NOT audible until they get into the sound system as clicks.
I have found that trying to record directely to a USB stick often has ooverruns and clicks... also burning a CD from stick to the CD results in noise due to buffer underuns. Burn from Hard drive to CD and make sure all the other hog programs are shut off.
Jan 04, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
BR-1180 Cd will not burn CD's does it call for
Don't know if this unit is sensitive to the type of CD, but my Phillips recorders will ONLY burn the "Music CD's" (harder to find, more expensive). Read up on the difference of regular vs Music CD's. ALSO some recorders will not burn disks rated at lower or higher rates.
Oct 10, 2009 | Boss Micro BR Digital Recorder
Oct 18, 2008 | Boss Micro BR Digital Recorder
Music Logo
20 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
