Question about Sewing Machines
Does it have a fuse and if so where is it located?
  • William Gilbert Mar 30, 2015
    Hi Ingrid Smith, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Is this a Sewing Machine?
    What Make and Model??
    President:
  • 1,702 Answers
Hi, It may just have a fuse in the peddle switch. Most likely.
Replace with same fuse. Good luck.
Posted on Mar 30, 2015
Locating fuse in bernina activa 220
Generally, there is no fuse issue. The problem will be a failed power supply (L-PCB). Suggest that you visit your Bernina dealer and get a new circuit. THe cost will be about $150.00.
Aug 04, 2014 | Bernina Sewing Machines
Fuse location inside
www.kenmore.com/kenmore-sewing-machines
I doubt that it has an intenal fuse, unless you are talking about an embeded one inside of the motor.
Jul 12, 2014 | Kenmore Sewing Machines
Where are the two fuses on the janome 6500
contact janome & ask them about the fuses
May 27, 2012 | Janome Sewing Machines
Where do I find the fuse location on the Janome MC 6600P?
The fuse is on the inside side of the inner circuit board behind the front panel. There are 2 fuses, top is 3.15 amp and the botom 2.5 amp
Feb 13, 2012 | Janome Memory Craft 5700
I can't find where the fuse is located on a phaff 1069. The manual I have is for a 1067, 1069 and 1047. The picture showing where the fuse is at is NOT in the same location.( Next to the power cord...
There is a fuse located on the circuit board that is in the main motor. You need to remove the top cover, front cover, and stitch buttons, cover. You will then see the main motor. Once you have it out, you need to be careful as you disassemble it, as it has 2 very fine copper wires that connect the circuit board to the field windings. Look for the fuse housing that is on the circuit board. If the fuse checks out good, check the motor carbons. They may be worn down far enough to not make contact with the armiture.
May 02, 2011 | PfaFF Tiptronic 2040
E1-Error message is apparently the fuse were is
The E1 error message. This is due to the fuse having to be switched from the 2.5 amp to a 3.5 amp. they did not recall the machine because of the low cost $2.99.
The Fuse is Located on the Board itself.
I guess the Part Number for your model is 000182177.
You could Purchase that from :-
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=000182177&productGroupId=0020&supplierId=385&pathTaken=&filterPart=&pop=flush
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 23, 2010 | Kenmore 19233 Computerized Sewing Machine
Locating fuse for the above
Which make a model is this? The line fuse should be located after the 120VAC line enters the sewing machine. Without knowing what model it is i can only give limited help. Unplug unit from the wall, and gain access to where the power cord enters the sewing machine chassis. There should be an internal fuse located shortly after. Let me know what model it is if what I have already said doesn't help you out.
Jan 27, 2010 | Sewing Machines
I have a pfaff 1473 the display blinks on and then off. The display stay stays off
Mine is doing that too. According to the manual, you need to replace the fuse. I'm having trouble locating where the fuse is though.
Dec 26, 2009 | PfaFF Sewing Machines
Janome/New Home Memory Craft 8000
I have a memory craft 8000 that gets a message stating "Stepping Motor Error". What can I do to try to fix it?
Oct 01, 2007 | Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
