Question about Amana Washing Machines
Amana washer model dlw330raw will not spin please help do you have any videos to help me fix this problem
  • Amana Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Posted on Apr 13, 2015
SOURCE: replace a belt on a amana dlw330raw
you flip the washer on its side
remove the screws on the side
take out the tub springs
remove the pulley
put the belt on bolt on the pulley
put the tub springs back hardest part in my opnion
replace the screws
test the washing machine
....it is no different than changing a belt on a car ....my best suggestion is that you take pictures at every step and stay organized...that way u can tell orientation of all the parts.
Posted on Mar 19, 2009
srsrs_1999
  • 9 Answers
SOURCE: AMANA WASHER WON'T SPIN. HOW DO I REPLACE THE BELT?
is this a whirlpool built amana? if so, its most likely a direct drive model, and when it doesn`t spin its likely a coupling between the gearcase and motor assembly...youtube has videos on how its replaced, which isn`t too complicated to do...good luck
Posted on Apr 30, 2009
  • 14 Answers
SOURCE: Washer wont work.
try putting it on spi - do you hear anything? could be a broken belt - very easy to fix.
Posted on Aug 26, 2009
heatman101
  • 43501 Answers
SOURCE: How do you replace the belt on an Amana washer
Here is a tip that will help you with that..
http://www.fixya.com/support/r4245827-dryer_belt_replacement_replace_dryer
heatman101
Posted on Apr 23, 2010
heatman101
  • 43501 Answers
SOURCE: Amana washer doesn't spin, model dlw330raw,
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 26, 2010
My Amana Washing machine model DLW330RAW makes a loud high pitch sound when on spin cycle. Could you tell me what it is?
loose drive belt ,if you have this noise then your clothes are not getting washed proply.adrian,,,,
Oct 30, 2010 | Washing Machines
I have an Amana Distinctions Washer DLW330RAW. I put a load in and in a couple of minutes had smoke. Shut it down and found the belt was broken and slightly burnt. I have replaced the belt but the...
The transmission is burned out. The same exact problem just occurred with my Amana Distinctions. Whirlpool will pay for this repair 'by concession'. Call the 800 number inside the lid and explain your problem, the operator should offer a free diagnostic visit and the repairman should offer free repair.
Aug 13, 2010 | Washing Machines
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
Mar 17, 2010 | Amana DLW330RA Top Load Washer
Apr 30, 2009 | Amana ALW480DA Top Load Washer
Replace a belt on a amana dlw330raw
remove the pulley
replace the screws
Dec 28, 2008 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
