Question about Altec Lansing Imt620 Inmotion Classic Portable Ipod Dock Fm Tuner
Iphone does not seat properly and cannot get sound
My iPhone 5c keeps saying SIM card not valid
Make sure sim card is seated properly
remove sim card and gently clean gold contacts with a pencil eraser or qtip dipped in alcohol..let dry be for re inserting
contact service provider and have a new sim card sent to you
Aug 15, 2016 | Apple iPhone 5c
2009 impala driver side power seat won't move up/down, makes whirring sound when attempted. Moves forward backward. Passenger seat works properly.
Before you do any of the expensive things disconnect and reconnect the wiring to the seat I had the same exact problem with my 2009 Chevy Impala and was ready to take it to the dealer when I disconnected the power cables to it and reconnected them I found that one of the Harnesses was loose and the problem was solved
Sep 12, 2012 | 2009 Chevrolet Impala
Fuel pump leaking oil
Sounds as though the pump isn't seated properly. I know the one bolt is hard to get to, however, if the pump isn't seated properly, it won't bring fuel up to the pump. May possibly need another gasket as well. But, from what the symptoms sound like, it's not getting fuel from the tank to the pump and most likely from the pump not seated properly.
Jan 03, 2012 | 1987 Suzuki Samurai
I replaced my lcdon my iphone 3g it lights up turns on but wont let me unlock
The ribbon cable for the digitizer (touch panel) is either loose, improperly seated, or broken.
Check the ribbon cable, if it is seated fine, you need to replace your digitizer.
May 04, 2011 | Apple iPhone 3G Black Smartphone
Sound goes out & speakers "disappear" from computer prefs panel
I would open it up (assuming it's a desktop pc not a laptop), and make sure the sound card (if it's an expansion card and not built-in to the motherboard), is properly seated (all the way in) in the expansion slot.
Feb 18, 2010 | Harman Kardon Harmon Kardon SoundStick II...
My iPhone 3G will not respond to iHome play/pause
Just solved exactly the same problem by powering off and on the iPhone
Jan 24, 2010 | Brookstone iHome Alarm Clock Radio Remote...
My iphone will not ring and i checked the orange dot
Some users who have recently updated/restored to the new iPhone firmware 3.0 have reported to have got into a problem where their phone randomly doesn’t ring when there is a call nor does the keyboard or slide to unlock button sound anymore. I got into this problem as well after unlocking and jailbreaking my iPhone 3G with firmware 3.0, my iPhone suddenly stopped ringing on calls randomly, resulting in missing a lot of important calls.
So if your iPhone isn’t ringing sound on calls, or if you are unable to hear the keyboard or slide to unlock click sounds, then try the following fixes before you panic and call Apple support:
Fix #1: Push feature is currently not working properly on jailbroken iPhone’s. If you have installed an application which supports Push Notification System then try disabling the Push feature as it may solve the problem.
Fix #2: Try Resetting the iPhone: Settings > General > Reset > Reset All Settings. This will reset your phone’s setting to factory defaults. Your contacts, calendars photos and any other data will stay intact.
Fix #3: There is a slight possibility that your iPhone’s headphone jack may have got some dust or rust which is causing the phone to think that the headphones are still plugged in when they actually aren’t. Try blowing out air in the headphone jack or try plugging the headphones in and out repeatedly. This trick may solve the no sound problem.
Fix #4: Restore/Update you iPhone back and start afresh: If the above solutions doesn’t help in solving your problem then you will have to start from scratch by first restoring your iPhone to the the original firmware
3.0 from iTunes, jailbreak it using redsn0w and then finally unlock(3G users only) it using ultrasn0w. This has fixed my problem.
Fix #5: Install Insomnia from Cydia: Install Insomnia as your last resort. When you press the power button on the top, iPhone goes into sleep mode after 30 seconds, in the process turning off your WiFi, sound and other stuff. When Insomnia app (available for free from Cydia) is enabled, applications will keep running and sound & WiFi will stay connected when the screen is off. This should fix your problem if all of the above solutions have failed to fix it.
Dec 30, 2009 | Apple iPhone Smartphone
YouTube on my non-jailbroken 3GS will lose sound
This is due to slow down the transmission rate of the data packets carried over the respective wi-fi network.
please switched off the iphone and then remove its cell for some minutes and then attach it gently with proper care and switched on the iphone.
ok ,Bi
Nov 29, 2009 | Apple iPhone Smartphone
Earpiece on iphone not working.
Sounds like the ear speaker connector wasn't connected properly upon reassembly, maybe the ribbon cable is torn. There is a stepby step guide toothat explainshow to properly reassemble the phone: iPhone repair. There are also third party iPhone repair companies that do it for you.
Sep 26, 2009 | Apple iPhone 3G
Altec Lansing Imt620 Inmotion Classic Portable Ipod Dock Fm Tuner Logo
59 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
