I think the maid dropped a small garment between the drum and the outer casing. Imposible to get my hand in there. When I tiltbthe drum I can feel it not moving all the way to the front wich suggest s
I think the maid dropped a small garment between the drum and the outer casing. Imposible to get my hand in there. When I tiltbthe drum I can feel it not moving all the way to the front wich suggest something is stuck down there. Any advise. Samsumg wa80g5 diamond drum.
    Top Expert:
  • 2,907 Answers
I would say, if there's something in there, the drum will have to be removed. Not an easy job.
You could try www.searsdirectparts.com
They have free diagrams and parts "blow-up diagrams.
They'll even fix it for you.
Posted on Mar 30, 2015
BELT BURNT FRAYED THEN BROKE, SOUNDED LIKE BEARING NOISE
It may be a garment stuck in between the inner drum and the outer shell
Aug 31, 2012 | GE WBVH6240F Front Load Washer
My machine seems to be creating "plucks" on garments. I've run my hand around the drum for any "spikes". Any idea why this is happening please?
I'm sorry to say that this is potentially very bad news. The problem you describe is quite possibly because the main bearing on the drum is worn out, allowing the inner drum to "flop about", when this happend, garments can get trapped between the inner and outer drums, causing pulls in the material and stain marks as the material is rubbed hard against the rubber gasket.
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed.
If the bearings are bad enough then other symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open.
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about ?£20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
Jul 28, 2011 | De Dietrich LZ9619 Front Load Washer /...
My Simpson Enduro 701 does not drain properly at final spin and quite often clothes are ripped.
Looks like you have 2 problems here. The draining issue is probably a blocked pump, but the ripping is far more serious as it's usually associated with garments getting caught between the inner drum and the outer drum. THIS is usually the result of faulty main bearings, which may, I'm sorry to say, be fatal. I have attached some generic advice below. Hope it heps you pinpoint the problems:
The problem you describe with clothes being ripped is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about"and trap clothing when it does.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about £20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
Turning to the issue with drain problems and wet garments:
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 11, 2011 | Washing Machines
Our LG washer is 4-5 years old. All of a sudden there is a slight scraping noise when the drum is turned. I can feel no resistance when turned by hand. It sounds like something may be between the stainless...
My LG WM-2277HW Front Load Washer had the same problem, I took it apart and it turned out to be heavy corrosion on the drum. just sand it back and it will be as good as new
May 03, 2011 | LG WM-2277HW Front Load Washer
Dryer heats up but does not rotate - only squeals
Check to see if the dryer drum will turn by hand. If not, look for a sock or other small garment that may be wedged between the drum and the dryer. It's remotely possible that the bearing has seized.
If the drum turns fairly easily by hand, the belt is probably loose (worn and stretched) and needs replacement. Check repairclinic.com for the part and a how-to video, if you want to try to repair it yourself.
Apr 29, 2011 | Frigidaire FEX831CS Top Load Stacked...
My ariston intergrated washing machine''s inner drum has dropped and is making alot of noise, it seems to be detached and ''loose'' from the outer drum casing
Either the main drum bearings have collpased, or the drum support has corroded and fractured, thus causing the drum to collapse.
It is a major repair, and quite expensive to put right.
In my experience. I think you would be well advised to consider replacing the washer.
Please rate my solution.
Thankyou.
Jan 24, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
The washer made a gringing noise on the last load and now the water didn't go into the drum but all over the floor.
Found a post online. A garment got lodged between the inner and outer drum blocking the fill port preventing the water from entering the machine - instead it came out the front of the machine at the detergent fill. Pulled out the garment and now works fine.
Nov 30, 2009 | Kenmore HE2 Plus Front Load Washer
I have dust under outer lens on my 75-300mm f/4 -5.6 III USM
Front element? You can remove this without alignment worries. The lens zoom mechanism tends to **** in the dust.
Have a look at the front element outer ring. There are 3 black screws. Remove these using jewellers screwdriver (y'know, a very small posi-drive one!). Remove this plastic outer ring. Now you can see three small silver screws, that are about the same size - when you try to unscrew them, they just rotate...
This is as they are not screws, but as mentioned elsewhere - they are plugs (if you notice, they are slightly under the casing. Get a small flat bladed screwdriver, and gently prise them out. Now you can just drop the front element into something sensible - like a microfibre cloth (give it a clean whilst you're there.
Get a rocket blower (NOT canned air), and blow away the dust, and you can use the microfibre cloth (or similar) on the small inner front element.
Then replace the outer front element - you will see where it drops into place - there are plastic guide tabs. Push back the silver 'screw' plugs.
Then screw back on the plastic outer ring and you're done - takes 20 minutes at the most.
Jul 02, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Candy Aquaviva 1300 washing machine
fabrick condictioner drawer stays full can you help me bernie
May 21, 2008 | Candy AQW130 Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
