Question about Compaq Evo N610C Notebook
High pitch noise
Whenever the laptop is turned on, it makes a high pitched squeal like a capacitor dischargind, someone told me that it was the dc converter board, if this is true where can i get the part for replacing this and is it easy to fix.
    Brigadier General:
  • 6,966 Answers
Re: high pitch noise
For laptop repairs & parts, pls try here. Not really that hard a fix but major concern is how soon do you get the parts and how to confirm your diagnosis.
You may want to consider other possibilities such as:
1. mechanical problem (fan motor bearing, CD/DVD spindle, HD platter; and/or
2. CCFLamp inverter.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 14, 2007
0 characters
3 Points
Hp altec lansing makes a beeping sound while starting
Try running a registry cleaning program. That should sort the errors out
May 20, 2014 | Acer PC Laptops
My dell d620 makes a constant high pitch screeching noise how do i make it stop
sounds like fan or possibly hard drive is about to fail
Jan 02, 2014 | Dell PC Laptops
Some keys not working, makes a high pitch noise when switched on
The high pitch sound may be the power supply adapter, unplug let it run on battery, if sound goes away change the power supply, the laptop keyboard will need to be replaced, go to Type make and model of laptop, refine search to keyboard and power supply if needed.
May 03, 2012 | Acer Aspire One AOD150-1165 Notebook
My laptop makes a high pitched noise
The high pitched noise you hear is most likely caused by the CPU cooling fan on your laptop. If you suspect that this high pitched sound is caused by the fan going out, you can spray your laptop with compressed air to get the dust off of the fan.
This solution will make your laptop work at a cooler temperature, and reduce the noise.
If the problem persists, seek a certified laptop repair specialist.
May 22, 2011 | PC Laptops
All my Dell power adapters are dying! I have 3 and none work now. The first one started saying it was not compatible, then the next one worked for a short period then the green light went out. I put one...
Yes! unfortunately it is, the reason why the power adapter has the high pitch noise is because the power supply is being loaded down by the motherboard, it may be due to the DC jack in the laptop or the charging circuits on the motherboard causing the problem. However there is one way to find out, remove the main battery to see if the high pitch noise goes away, if it does! it will prove where the problem is. It is also very possible that the battery is loading the whole circuitry, because it may have a high resistance short, enough to cook the power supply, I have seen this in very rare cases and is one for the books.
Mar 11, 2011 | Dell Inspiron 5100 Laptop
My Acer Aspire 5100 laptop makes a loud high pitched consistent noise when I try to turn it on. then the noise stops, then a black screen comes up with writing, but when i hit resume, the computer restarts...
The problem might be the power supply charger that plugs into the laptop, unplug the charger and run the laptop on battery power, is the high pitch sound there when you power up? if this solves the problem, it is the power supply charger that is the cause.
Jan 08, 2011 | Acer Aspire 5100 Notebook
My laptop makes a noise while playing audio file
This is due to improper gronding or connected the speaker wire reversed. rectify the same will resolve your problem.
Thank you for using Fixya.
Apr 13, 2010 | PC Laptops
Hi i have hust turned my laptop on and it is making a biig noise and it is not stopping it comes on when u turn it on what should i do
Are you getting a high pitch screaming or a grinding noise? The Fan on the heatsink sometimes getting clogged with dust and over time this can cause the computer to turn itself off. Dependant on a high pitch scream this could be a number of problems, memory modules loose or faulty?? Would need more info about the type of sound..
Nov 07, 2009 | Medion md40298 Notebook
Hi grade laptop makes high pitched noise and the screen is blank
High pitch noise usually means the inverter board that drives the lamp behind the LCD display. If the rest of the laptop appears to work, for example, hard drive light blinking while booting, try hooking up an external monitor and hit whatever function key that switches you to the external monitor. If everything works, you may want to replace the inverter board yourself. It is not horribly hard if you are very careful. But it is not exactly a walk in the park kind of work.
If the rest of the laptop does not appear to work, the DC-DC step down power circuit is probably shot, which will also make a high pitch noise. In this case, you will have to replace the motherboard. Replacing a motherboard is a major pain in the behind. In most case, it is not worth the trouble if you have an older model.
Sep 02, 2009 | Dell Inspiron 6000 Notebook
Hi, Meens here In my Acer Aspire 5920 Vista home preimum getting weird sound frm inbuild microphone after swtich on n the sounds stops after plugging headfons :(
The usual cause of microphone noise is caused by audio settings where the microphone gain may be turned up to high causing it to pick up noise from the computer or built in speakes. This can cause noise ranging from an odd hum to a high pitched squeal.
Check your sound setting first
Jul 12, 2009 | Acer Aspire One PC Notebook
Compaq Evo N610C Notebook Logo
225 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
