Question about LG WM2701HV Front Load Ultra Capacity Washer with Wash Motion Technology, Graphite Stee4.5 cu.ft. Ultra Capacity with NeveRust Stainless Steel Drum IEC, Direct Drive Motor for the Ultimate in Durability and Reliability, 10 TilTub for Easy Reach into the
What is the button combination to put the LG washer in test mode?
Do you know the button combination to put the washer in test mode?
  • LG Master
  • 2,226 Answers
I believe it is the power button along with the two center buttons on the right.
Posted on Mar 31, 2015
  • Jesse Astorga
    Jesse Astorga Apr 01, 2015
    My thanks to rdjagger. That was indeed the combination I needed.
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
The washer must be empty and the controls must be in the off state.
1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
2. Press the Power button, while the above condition. Then buzzer will sound twice.
3. Press the Start/Pause button repeatedly to cycle through the test modes.
Posted on May 05, 2015
How do I put my Frigidaire front loader into test mode?
Hello Angel BriBri, that's a great question!
I see that you would like to put your Frigidaire washer into test mode and you do not have the available buttons listed on the average test. Could you please provide me with your model number? You can usually locate the model number on the serial tag which can be found on the door frame of your washer. With that information I can look over your manual to see if I can locate the diagnostic mode. I look forward to assisting you. -Matt
Oct 18, 2014 | Frigidaire Washing Machines
LG WM1832CW, what is the key code combination to cause it to spin only?
The machine has a "Rinse & Spin" button in the "Options" side of the control panel. Press this button to accomplish the spin "cycle" that you require.
Oct 12, 2014 | LG WM-1832C Front Load Washer
Lg tromm wm2277hw will not spin
Press the SPIN SPEED and SOIL LEVEL buttons simultaneously to enter QC test mode and check the frequency of the water level, if the display shows 248 or more:
NO: Check the sensor switch assembly and also the pressure hose, replace either if faulty.
YES: Press the START/PAUSE button twice while in QC test mode and check whether the drum spins at low speed, this is normal.
If no reaction from the drum at all the the main PWB assembly board will need replacing.
Feb 09, 2014 | LG WM-2277HW Front Load Washer
Pulled tear drop locking mechanism down but keeps springing back NFW7200TW
it looks like you have a bad door switch and is the easiest and cheapest thing to fix on the washer part number 8182634 and it's around 65 dollars.open the door unplug the washer,remove the spring and pull off the rubber boot enough to get at the door switch,remove the screws pull out the switch and unplug it,put it back together,put some soap on the spring so it will go back on easier.hope this helps,also in the washer there's a tech sheet with all the codes and tells you how to run in diagnostics
Apr 07, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
Unlock code for LG KP500, free and it would be good if it was'nt BS. I've tried 2945#*# and 2945#*7101# etc. none of them worked, it just said ''please try again'' thx in advance
some cod
Lg old and New
LG Chocolate =2945#*#
lg kf700 =3845#*700#
lg ku250 =26911147#*250#
LG 900 v09e
Citazione:
TEST MENU: 277634#*#
LG 900 v10b
Citazione:
TEST MENU: 082065#*#
LG U970 Shine
Citazione:
TEST MENU: 26911147#*970#
LG L600V
Citazione:
TEST MENU: 63342425#*#
LG KU310
Citazione:
ENGINEER MODE: *72346#96
LG KU800
Citazione:
TEST MENU: 26911147#*#
LG KU830
Citazione:
LG KU950
Citazione:
TEST MENU: 7973845#*#
ENGINEER MODE: 21738#96
LG KU990
Citazione:
TEST MENU: 3845#*990#
ENGINEER MODE: 364663#96
MENU NCK: 2945#*990#
KF310 kF311 reset codes
Test menu: 3845#*310#
for kf311 3845#*311#
engineer mode: 364663#31
menu : 2945#*#
This procedure is for LG CT810.
To RESET your phone back to factory defaults which will erase all current content and revert the device back to original shipped configuration:
1. Turn off your phone,
2. Remove the back panel and take out the battery for about 30 seconds,
3. Put the battery back into the device and replace back panel,
4. YOU MUST PRESS AND HOLD THE FOLLOWING BUTTONS SIMULTANEOUSLY!
a. Left Volume Down Button, AND
b.Right Camera Button, AND Power Button
5.Hold them until you see the green Windows Mobile startup screen and then you can let go,
6. After a few moments, you should see the initial screen caliberation screen,
7.Your device is now RESET/RESTORED to Factory Default (this assumes you have not applied a custom ROM, in which case the reset will simply go back to the defaults of that package)
LG XENON Reset.....Security Solved!!!!
Lg security solved!!!!
Hi there, follow the steps below for LG XENON
remove sim card and tap emergency or From the standby screen
- Select Dialing Button
- Dial "3845#*500#" (you will then be in the engineering menu)
then reset phone
voila password gone
done it already
Pics Here
LG KE850 ***** security
without and with simcard: 1475369586#*# try this one too: 338464#*# ,then go Reset or restore default.
LG KU800 reset code = 277634#*#
kf311/310 =no sim inside
3845#*310#
KT520 user code reset =338464#*#
Sep 30, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
LG Model LHT754 stuck in demo mode
press power button on tv,then scroll right to take it back to tv
Jun 30, 2017 | Audio Players & Recorders
hold the stop button on the receiver not the remote! for twenty seconds
May 24, 2008 | LG LHT734 System
Hotpoint acquiarius WF645
To exit test mode, press start, display goes wild) press start again (display settles down) Then press on/off button and start buttons to gether and hold for a few seconds, machine will now read D;end, or similar, will now work okay
Jul 07, 2007 | Hotpoint WF645 Front Load Washer
LG WM2701HV Front Load Ultra Capacity Washer with Wash Motion Technology, Graphite Stee4.5 cu.ft. Ultra Capacity with NeveRust Stainless Steel Drum IEC, Direct Drive Motor for the Ultimate in Durability and Reliability, 10 TilTub for Easy Reach into the Logo
565 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
