Question about LG WM2701HV Washer
My LG wm2701hv washer will only turn on if I disconnect for 20 seconds and reconnect. Once the load finishes I have to do the same thing all over again. Any ideas?
  • LG Master
  • 2,184 Answers
Try holding in the power button for 10-15 seconds while unplugged, if that does not reset, try the same just after plugging back in. good luck.
Posted on Mar 31, 2015
Wont dispense bleach
you can used any compartments from 03,,,,
Jan 09, 2014 | LG WM2701HV 4.5 Cu. Ft. Front-Load Washer...
I have a LG WM2701HV it is a year old and sometimes the washer is not turing on and doesn't turn. I have checked the wall outlet and other electronics work in it and the breaker. Help!!
Hi Robert.
If the washer is occasionally not starting there may be an inlet problem or the door switch may be defective.
Most LG washers display error IE (inlet) or DE (door) if the problem is detected. In some case the washer simply does not start.
Check that there is pressure from the house.
If machine does not fill the inlet valve must be tested. The resistance across valve's terminals must be between 0.8 and 1.2 KOhms
The valve must get 120VAC in first part of the cycle. Testing must be done by a trained person.
If the problem is intermittent the problem is more likely the door switch.
The door switch assembly is held by two screw. The door lock must click once or twice when the start/pause button is pressed to start the cycle.
The door switch can be tested reading impedance across its contacts. The reading must change between infinity and zero when the door is opened and closed.
In some occasion overloading may result in the washer not starting. Check if the problem happens in coincidence with overloading.
Dec 28, 2011 | LG WM2701HV Washer
Lg WM2701hv hose squeals while filling
The only solution would be to replace the water valve. You will need a qualified technician to help you.
Good luck
Jun 10, 2011 | LG WM-2277HW Front Load Washer
I have a LG WM2701HV it is less than a year old and sometimes the washer turns on and other times it doesn't turn. I have checked the wall outlet and other electronics work in it and the breaker is...
How much soap are yall using? The washer is supposed to wash with less water. Too much soap causes problemas. Less than a year? Look for items in the filter.
Jun 09, 2011 | LG WM2701HV Washer
Sears botched repair on my LG washer (Model WM2701HV). Replaced both boards but suddenly motor does not spin - only hums. Tech claims motor needs to be replaced but it was fine until they replaced the...
If a LG washer hums look into a part called a HALL SENSER it is a small part that go's in the motor at the rear of unit they are known to go and the humming is the give away ..If this helped please vote if you need more help please feel free to contact me..czerney@msn.com
Feb 02, 2011 | LG WM2701HV Washer
LG Washer stops when it gets to rinse cycle
Code flashing IE? The code means the machine is not getting enough rinse water. Remove the hoses from the back i=of the machine, pull out screens, cold water is blue tab inside connection on washer, hot water is red. Clean screens and insert them back into the appropriate connection. Use a stiff brush and water to clean. Reset the machine by disconnecting power, press start/pause button(blue button on right) for at least five seconds, reconnect power.
Oct 31, 2010 | LG WM2277H Front Load Washer
I have letters le flashing on my lg front loading washer it won't spin
Sep 25, 2010 | LG WM2277HBW XL Front Load Stackable...
Wont finish the load
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Jul 21, 2010 | LG WM2701HV Washer
Set the keyless entry
TS06 DEC 05 Keyless Entry - Transmitter(s) Inoperative
There was a recall in DEC. 05 for this particular vehicles remote transmitter system....though im not sure if they would do service free of charge now...
Moving along...if you have no working transmitter, you have to do the following to get it working again:
* Ensure vehicle audio PIN number is known or audio PIN security system is deactivated prior to battery disconnection.
* Ensure a door is open
* Disconnect the negative battery cable, wait minimum 5 seconds then reconnect
* Within 20 seconds of reconnecting the battery cable, insert the keyin ignition then cycle the ignition key from the "ACC" position to the"ON" position 20 times, leaving the key in the "OFF" position after thetwentieth turn.
* the vehicle's indicators will flash 20 times to indicate successfulentry. NOTE: Should the indicators fail to flash, wait 5 seconds thenquickly turn the ignition switch from the "ACC" to "ON" position 10times, leave the ignition "OFF" after the 10th turn and wait 15 secondsthen recycle the ignition switch 20 times.
* the vehicle's indicators will flash 20 times to indicate successful entry.
* within 10 seconds of the indicators having ceased flashing, press the button once on each transmitter.
* turn the ignition key to the "ON" position to lock in and exit from the programming mode.
And if you have even 1 transmitter that does work, its not nearly as difficult:
* ensure a door is open
* remove key from ignition
* lock the doors using the transmitter
* unlock the doors using the transmitter
Within 20 seconds of unlocking, insert key in ignition, turn theignition key from the "ACC" position to the "ON" position 20 times,leaving the key in the "OFF" position after the twentieth turn.
The vehicle's indicators will flash 20 times to indicate successful entry.
Within 10 seconds of the indicators having ceased flashing, press thebutton once on each transmitter. Once finished, turn the ignition keyto the "ON" position to lock in and exit from the programming mode.
Hope this helped,
Jem
Nov 12, 2008 | 2004 Suzuki Verona
LG WM2701HV Washer Logo
132 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
