Question about Garden
How do I remove the steering hydraulic cylinder on a 5200 john deere? thanks
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
Posted on Nov 15, 2009
wfservices
  • 260 Answers
SOURCE: i need to rebuild a hydraulic cylinder on a john
  1. This cylinder is not to hard to disassemble.
  2. Place upright in vise or suitable bracing.
  3. Using a block or dowel of wood(maybe rubber mallet also), depress the top cap of the cylinder to relieve tension on the ring.
  4. Use a small edged screw driver or pick and spin "retainer" in until the bent end comes to the opening.
  5. Lift up and rotate the ring more to allow the ring to pass over the edge of the opening.
  6. Once the retainer is started you can tap it with the wood and rubber mallet around the circumference of the cylinder to release the retainer from the groove.
  7. If you havent done so by now the oil should be drained.
  8. with the cylinder firm in vise(but not too firm to "distort the integrity of the cylinder.) Place the cylinder Sideways so you can pull out piston and rod assembly.*** Put hose or suitable drain on holes of cylinder***. With the motion of the piston the residual oil will tend to spray out.
  9. Pull on the piston and position it to bottom out on the top gland(cap) ie:full extension
  10. Place support under the rod to avoid damage. The gland is a tight tolerant fit with use of O-rings and backup rings. Too much offset can lead to damaging gland assembly, and jamming in the cylinder. You may be able to just hold with hand also depends on size, bore, stroke, pressure rating. Use due dilligence.
  11. Now that its out you have the piston assembly with gland in hand..**if only the rod comes out there are more steps to take, and you need a new rod but sometimes its more cost effective to buy a new cylinder. If there is a farm supplier or hydraulic dealer near they can certifiably /replace repair the cylinder for you. Hydraulic pressure is kind of like lightening. If it strikes you under pressure it can kill you.*** Using the dead blow or rubber mallet try to pop the gland out by using the piston/rod assembly as the puller. You may not have to remove the top clevice or other end of the cylinder, so maybe you could tap on that.
  12. The piston can be removed from the rod depending again on make. Usually a socket head cap screw or king nut holding it in place to the rod.
  13. When the piston is removed you should be able to slide gland off also.
  14. You'll need that pick and or the screwdriver to pick out the seals carefully. Let me know if you require more...WF Services
Posted on Apr 07, 2010
I have a john deere 5210 and has a bad seal on the hydraulic steering cylinder how do i take the whole thing off??
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 28, 2017 | John Deere Garden
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
John deer 824 forklift forks don't have enough strength to go up unless the steering wheel gets turned to one side.
Not "strength" it sounds like you're so low on hydraulic fluid that only when you retract the steering cylinder is there enough to go up.
Good way to mess up your hydraulic pump. Add more fluid.
Oct 04, 2014 | Garden
How do you replace/ the hydraulic steering ram seals on a john deer 6900 agricultural tractor ?
If your mechandal include end of cylinder is a snap ring. Remove it and remove assembly. Replace seals then reassembly
Sep 22, 2014 | Garden
Case 1494 steering doesn't work, hydraulic
Hi Jas,
It is likely that you have a stuck or defective relief or bypass valve in the steering box. If all other hydraulics are working normally then the issue is in the steering box. Some units have a small screen filter on the high side line but usually that presents as jerky steering rather than complete failure. I do not recommend attempting repairs unless you have a pressure gauge to set the relief pressure after removal. You may find a used box on EBay, otherwise, find a local hydraulics shop to have it repaired.
Kevin
Dec 15, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
Sep 27, 2009 | John Deere 3 Pt. Hitch Moldboard Plow...
Garden Logo
209 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
