Question about Tablets & eReaders
My tablet will not come on I try charging it.
Will not come on
The charger no longer charging the tablet all the home outlets have been checked, & working with my other tablet. What could be the issue I received this as Mothers day gift
the charging circuit does not charge or the batteries need replacement ....IT is probably the batter. Try new batteries, if they work the problem lies elsewhere
Also, try a different charger, and the tablets charger on something else...if the tablet's carger charges other batteries that can be discounted as the problem.
May 26, 2015 | Nextbook Premium 8 Se Android
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
It will not charge
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Feb 15, 2014 | Ematic 7" Tablet Computer
Irulu tablet wont charge
These are the videos which will help you why tablet is not getting charged and solution to overcome
Try to use USB and charge it with it
and then after 10 min try to start the tablet
Jan 16, 2014 | Irulu 7 Touch
Tablet won't turn on
When you plug in the tablet to a charger, does the LED come on indicating that it is charging? If not, your tablet's battery is probably dead and you may have a dead charger. Try connecting your tablet to a PC's USB port, with the PC turned on, of course.
Leave the tablet connected and the PC on overnight. That should trickle charge your tablet enough that it will power on. If that doesn't work, your tablet may have a bad battery, a bad charging port, or your charging cable is bad. Try it with a different cable as that is the cheapest solution at that point.
Jan 10, 2014 | Samsung Galaxy Tab Tablet PC
My tablet won't charge.why???please help!!
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
Dec 29, 2013 | Dell Latitude XT2 Tablet PC
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
Tablet nextbook wont stay charged
try buying new tablet or charger as back up but also sometimes if my tablet will not charge like urs i just re plug it in . but before back ups try new ac adapter thingy
Feb 08, 2013 | E FUN Android Tablet Next7p12
Tablets & eReaders Logo
32 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
