My NAD 6040 Cassette deck keeps stopping after a few seconds when in play mode or rewind/forward mode...any solution to this.
  • Audio Player... Master
  • 1,267 Answers
The solution is to have a Technician work on it or fix it yourself if you have the ability. I work on decks 12-14 hours a day so this would not be hard to figure out. Probably a belt is due to be changed.
Posted on Apr 02, 2015
Denon DRM 740 tape does not play
hmmm...sounds like the transport motor/foot are stuck..open it up, and inspect around those items(where the tape actually clamps down) and see if you can see anything in there. Might even be a bug, no fooling..
as to repairs..you are most likely talking some major money, and a long time in the repair depot, which I believe is in Rio..I'll check that for you while you do this part.
Mar 16, 2008 | Denon DRM-740 Single Dual Cassette Deck
Panasonic SC-AK45 stereo not playing cassette tapes
I may not have worked on one of these before but all tape decks have some common drive parts. Yours is missing the proper torque to drive the reel table in take-up for play and your fast wind observation also points to either drive transfer problems or the motor itself. I suspect the fastest answer is to have a tape deck technician work on it. Dual cassette decks are not known for being the long lasting products like a singles cassette deck is.
Feb 23, 2013 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
GE VG4056 will not rewind
The photo sensor that senses the tape end has blown or dry soldered.It is on the right side of the mechanical deck and senses the transparent end of the tape through the square hole in the video cassette.
Apr 27, 2008 | GE VG4056 VHS VCR
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
247 people viewed this question
 Grubhead
Grubhead
