Question about Zanussi Washing Machines
Zanussi washing machine doesnt do a full wash just goes straight to drain if someone could help I would be very grateful
  • Zanussi Master
  • 5,323 Answers
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Posted on Apr 13, 2015
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Posted on Jul 28, 2008
  • 135 Answers
SOURCE: zanussi washing machine zwf1437w error code e30
E30 indicates a pressure system fault. There can be several causes but the most frequent is a blockage in the system.
First thing to do is check the filter on front of machine.
Please do this and report your findings.
Posted on Jan 29, 2009
bozcro
  • 867 Answers
SOURCE: Zanussi ZWD1470W fabric conditioner compartment won't drain
fabric conditioner is dispensed during rinse cycle, if it does not work then either, try pouring hot water into dispenser, as conditioner tends to get goopie when dry, thus may have clogged up
Posted on Dec 11, 2009
When power on and selected cycle goes straight into drain
Zanussi has a safety function on its machines. If the machine has a major fault the only thing that will function is drain. This is ensuring the machine can be emptied of water prior to working on it. unfortunately this doesnt help you because the problem will have to be established by trial and error
May 24, 2010 | Zanussi ZWF1430W Front Load Washer
My Zanussi zwx1605w
norm faulty heater/element iff not faulty pcb
Jul 13, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi washing machine zwf1437w error code e30
Jan 29, 2009 | Zanussi FJS1225W Front Load Washer
Washing cycles
if you put machine on a delicates or wool wash, it will stop still full of water giving you the choice to only drain or drain and spin
Sep 10, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi FC1200W
hope this helps
Jul 28, 2008 | Zanussi FC1200W Front Load Washer
Zanussi washing machine wont spin
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Washing machine displays E30
I have just had the same fault on a ZWF1631W machine. The machine overfills and goes straight to drain.
The level is controlled by an air pressure switch.
Remove the machine top, the switch is the round white plastic one. On mine, one of the wires had broken off. I had to replace the connector with .25" crimps.
If not, the switch may need replacing.
Sparks
Mar 07, 2008 | Zanussi ZWF1630 Front Load Washer
Egg smell at start of wash.
Make sure that the drain hose is connected correctly, and that there isn't a direct run down from the sink u-bend to the washing machine. This can allow some of the dirty water running down the sink to run down the drain hose into the washing machine. A drain hose that is connected to a sink u-bend should first go up at least 3 or 4 inches high (it may need tying up) before running down to the washing machine. Good luck!
Sep 13, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
