Question about KitchenAid KGRT607 Gas Kitchen Range
What is error code F3E0 - KitchenAid KGRT607 Gas Kitchen Range
Error F3E0
next time you see the error codes, write them down. F3E0 is open sensor error . I don't think you have an oven sensor error or a problem with the sensor. When the oven works the temperatures are good so the sensor won't be open. F0E0 is "No Error" and "No Action Required". It sounds like a loose or a bad connection in the control section. There is no connection between the oven door and the control panel. Opening and closing the door to clear error codes or to get the oven to work is jarring the control and the loose or bad connection to the point it makes contact and works. Start with the ribbon connector and remove and reinsert it. You can also use a pencil eraser to gently clean the end of the ribbon connector. Remove and reinstall the wire harness connectors on the boards. Make sure all the pins in the connector are in place and not starting to come out the back of the connector.
Sep 30, 2016 | Ovens
Why does oven show F3E0 when turned on?
That's error F3 E0 indicates a bad temperature sensor and/or thermal fuse. Did this happen after self cleaning?
Sep 26, 2014 | Whirlpool Ovens
KEMS308SSS KitchenAid Wall oven - Error F3E0 - Sensor seems OK
The RTD could be in spec at room temperature but failing under load
May 21, 2013 | KitchenAid Architect® KEMS308SSS Stainless...
Wirlpool mod#sf367lxss0/F3e0 code given,oven lights up,dosen't stay on.i get could be's should be's,expeesive non-needed parts.whts it mean?thnks..
Hello & Welcome to FixYa
F3 E0 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 14, 2011 | Ovens
F3e0 error
may need more info.what sequince happens before this error occurs.does any other function operate correctly.
Oct 09, 2009 | Whirlpool SF367 Gas Kitchen Range
Error code f3e0, oven wont turn on, follow instructions to set temp, after hitting start, get 3 beeps.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Oct 03, 2009 | KitchenAid KGST307 Gas Kitchen Range
F2E1, F3E0 Error Codes
Believe it or not, but on my Whirlpool Estate (Model: TES400PXHQ0)....after reading about this error, I looked at the sensor, and I noticed it was touching the metal on the inside of my oven. I moved the sensor away just by pulling on it to the center of the hole that was cut out for it, plugged the oven in....and didnt get a code at all....not even the PF code. So, I tried the oven out....expecting for it to beep at any second, and it didnt!!!!
So, in conclusion.....I guess by the sensor touching the metal on the inside, it couldnt get an accurate reading, so the computer threw out the infamous F3E0 error.
I've had this oven for 4 months and always had to stare at the F3E0 display (it was donated to me). Thanks for all who had done the research on this to point me in the right direction, as Whirlpool wanted someone to come out at $60 just to come out, then $80/hr!
Thanks again
~Luke
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
F3E0
F3 means the oven temp sensor has failed E0 means it failed open If you have a test meter i can tell you the resistance at room temp is 1100ohms. otherwise call for service Hope this helps PLEASE rate my solution Thnks...
Oct 02, 2007 | Whirlpool SF315 Dual Fuel (Electric and...
KitchenAid KGRT607 Gas Kitchen Range Logo
59 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
