Question about Black & Decker HandyChopper Plus Food Processor
The motor will not start. What can I do?
Motor will not start.
How can I test the motor relay on a Magimix food processor?
Overloading may have caused a thermal protector buried in the motor windings to open in which case the motor will have to be replaced.
Jun 04, 2016 | Magimix 4100 Cuisine Systeme 1268 Cups...
When turn the switch on after 2 minutes start smoking from motor
Sam, discontinue use, motor is obviously about to burn out. Probably not cost effective to repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 23, 2016 | Food Processors
Motor humming but drive shaft not moving
I would suspect either the starting capacitor on the motor or worst case the motor itself. The capacitors are a fairly common item to fail while the motors are uncommon. Expect a new motor to be extremely expensive.
Jan 24, 2016 | Magimix 3200 Food Processor
I press a button n it blinks then all the buttons start blinking and the motor never starts.
The motor is most likely open circuit. Solutions are going to be either replace the motor OR if the thermal fuse on the windings is blown you will need to get one of the same value and replace it. The value is written on the fuse and it is under some fibreglass tape on the field winding with the aluminium clip around it. You need to remove the motor completely to do it.
Jan 05, 2014 | Wolfgang Puck Bistro 620 Food Processor
Why won't the food processor start
Hello :
If the cord is OK , then it seems that the motor armature is burn .
If you can fix it by yourdelf , then dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper color. If the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor . Or take it to a repair shop if you are not sure that you can fix it by yourself .
good luck .
please rate !
Mar 28, 2010 | Krups XL6 Power Combi Food Processor
The motor just humms loudly when I try to start it. If I give it a push it will start spinning, but boggs down if I put any food through it
Take the bottom plate off to expose the motor, drive belt, and pulleys (pull the power plug for this). Remove the drive belt and turn the motor shaft by hand--does it seem to turn freely? Do the same with the driven pulley--it should turn freely also. The pulleys and belt are likely cog-type and not prone to slippage. If either pulley shaft is excessively hard to turn, then investigate the reason,and replace parts if necessary. With the belt off, the motor should accelerate almost instantly. If relatively slowly, the motor may need to be replaced.
Jan 31, 2010 | Kenmore KFP-70 Food Processor
Won't start
Make sure it is unplugged !!! If you have a blade tool, Rotate the motor several times in direction of normal rotation. Then all clear, plug it in and see how that does. Repeat if necessary. Sometimes the brushes in the motor are seated and turning the motor helps the realignment. mAKE SURE TO UNPLUG IT!!!! Ned
Oct 30, 2009 | Cuisinart DFP-11 Deluxe Food Processor
Makes humming sound motor will not spin
Did you replace the start capacitor or start relay first ? This is the most common problem & a hell of alot cheaper than a new motor. Did you replace the motor shaft seal (around the shaft on top of the unit ? if not you will be replacing the motor sooner than you need to because the acids from veggies eat these things up & is the main reason why the motors fail, next in line is overloading or forcing product.
Sep 15, 2008 | Robot Coupe Blixer BX6 Food Processor
Black & Decker HandyChopper Plus Food Processor Logo
81 people viewed this question
Top Black & Decker Food Processors Experts
Holly...
Holly...
Jim Thurston
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
