Question about Brother IntelliFax-2820 Laser Fax
Does anybody know how to print a fax history from a Brother IntelliFax-2820?
JayBlair
  • 328 Answers
SOURCE: can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
Posted on Aug 01, 2007
leroyal
  • 2120 Answers
SOURCE: Brother IntelliFax-2820
What is your email address?
Posted on Oct 01, 2008
  • 37 Answers
SOURCE: Time Change on Brother 2820
1.Press menu
2.Press 0
3.Press 2
4.Enter the last two digits of the year on the
dial pad, and then press Set.
5.Enter the two digits for the month on the dial
6.Enter the two digits for the day on the dial
7.Enter the time in 24-hour format on the dial
8.Press Stop/Exit.
Posted on Mar 02, 2009
  • 46 Answers
SOURCE: REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Posted on Sep 03, 2009
FixinFax
  • 3085 Answers
SOURCE: I am sending a fax on a Brother Intellifax 2820
Face down
Posted on Jul 02, 2010
How do you get the transmission fax history on a Brothers Intellifax 2820?
If it has a "report" button, press that and select the one you need. If not, hit menu (or function) and scroll through to get to the report you need.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
How do I set the machine to receive automatic instead of manually
go to initial set up , receive mode, change it to fax only
May 24, 2010 | Brother IntelliFax-2820 Laser Fax
Need to know how to print FAX report showing when items were faxed to what number on Brother IntelliFAX 2820
Press the report button and chose Fax journal with the down arrows and press menu/set. This will print the last 50 incomming and outgoing faxes.
Dec 28, 2009 | Brother IntelliFax-2820 Laser Fax
How do i get my brother intellifax 2820 to time stamp the faxes i receive.
From everything that I've seen I don't see any way to tim stamp incoming faxes. Almost all fax machines should automatically time stamp outgoing faxes unless the user has removed that function for some reason. If you are getting faxes from people that don't include time stamps than the next best thing is to use the journaling feature. The 2820 can print a journal of past incoming faxes that will include timestamps of the past faxes recieved in either 6,12,24 hour or 2, 7 day intervals. The default is every 50 faxes. To change the settings:
Press Menu/Set, 2,4,2
2. Journal Period
Use Arrows to choose an interval
Press Menu/Set
Press Stop/Exit
Jun 22, 2009 | Brother IntelliFax-2820 Laser Fax
Fax brother 2820
Try unplugging the power cord for 10 seconds.
Jan 15, 2009 | Brother IntelliFax-2820 Laser Fax
Fax reports
press the help button.this will print important function to help you program features of your fax machine
May 14, 2008 | Brother IntelliFax-2820 Laser Fax
Prints with a white line vertically down the page. How can I fix this?
Apr 25, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
89 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
