Question about Electric Garden
What is the max length of electric cord I can use with this machine?1800W 50Hz?
  • Electric Master
  • 2,760 Answers
Its not what is the max length you can use on this machine , as this one if it operates at 220 volt 50hz only draws a little over 8 amps , but how large the circuit supplying is fused for , as 200 ft of 16 ga power cord would provide a voltage drop to only 207 volts (vs 220 volts) this would now make your tool draw a little less than 9amps plus your tool is not operating at its full voltage/speed and it heats up more and does less work so will take longer to do same work
any cord length that produces a total current load to near or over 15 amps total load is gonna produce problems for both tool and operator
Posted on Jun 04, 2015
Hi I have a Husqvarna trimmer the blade on the guard is missing and just wondering if its worth while replacing the part? Also is this model a bumper feed or stop and go feed?
press on the feed section and if you can press it in it will be a bump feed
as for the blade, it is there to cut the string to the correct length
electric motors do not like spinning extra cord as it overloads the motor take it in to a mower shop for assessment
Oct 05, 2016 | Husqvarna Garden
I am considering buying a BT phone model bt8500 and need to know the length of the electrical lead included, not the phone socket cable, to see if my electric socket is near enough. Can you help please ?...
i do not think or care how long the electrical cord can be, as long as you have hot (positive) + cold (negative) line, when i ran phone lines in the military we ran wire up to 1 mile and we can test it with electric and ohms meter. both way works, and i know you are not running the wire a mile long. have 60hz or 50hz cycles every second flopping in both direction 60hz or 50hz off set. here is a formulas
to help you:
f is the frequency in kilohertz,
x is the wavelength in meter
300,000 300,000
f = --------------- x = --------------------------
x f
if either the frequency or the wavelength is known, the other can be computed as follows.
Feb 26, 2015 | Socket Computers & Internet
Wolf 5000kva generator
Locate where the choke lever is for your generator (under the petrol tank), you ought to notice a star headed shaped screw connected to the governor shaft (if you bend and look closely further beyond the choke lever; still under the petrol tank) which is linked to the carburettor housing/assembly. You need to increase/turn clockwise (using a star screwdriver) on this screw.
Your generator engine sound will change/high a bit because the engine speed will increase.
Reconnect your 1800w chop saw (load) and see if your generator can "effortlessly" accommodate it without shutting down otherwise, increae the turns on this adjustment screw attached to the governor shaft till your generator operates/stabilizes with the load (1800w) connected
Oct 05, 2017 | Wolf Manufacturing Electrical Supplies
Can lg 50hz washing machine run on 60hz
yes but I will not good IDEA you will have phenomen transistory is electrical term in engineeering electric, you must get support via ONLINE chat or phone with LG.
you must transform the 60hz to 50hz or 50hz TO 60hz.
God bless you
Sep 30, 2012 | LG WM-1832C Front Load Washer
I need a longer power cord for my GE 12 cup percolator. It has three prongs.
Hi, My advice is don't make the cord too long. they can heat up and start on fire if its too long.
You can get a power bar and screw it to the under side of the cupboard. good luck
Jul 18, 2011 | GE Coffee Makers & Espresso Machines
WHAT SIZE EXTENSION CORD FOR GA7021 SHOULD I USE AND MAX LENGHT? BURNING UP GRINDERS
Well for 15A the minimum wire size in your cord should 14 gauge, Length can't really be specified but you want to go for less resistance in the cord, thicker wire and less length will give you less resistance (more so thickness). If your grinder works fine without the extension cord, I would recommend getting a heavy duty extension cord with 12 gauge wire and trying that.
May 25, 2010 | Makita Angle Grinder 7" 6600 Rpm, 15 Amp
Voltage difference
The voltage difference can be overcome. The problem will be the difference in frequency 50hz vs 60hz. The motors would have to be replaced with motors designed to operate at 50hz. The electronics would most likely need to be replace as well.
Best bet would be to contact whirlpool international to see if the offer a conversion kit/package.
Feb 02, 2009 | Whirlpool LER5636P Electric Dryer
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
Electric cord for Wolfgang Puck griddle
I NEED A ELECTRIC CORD FOR WR APPLIANCE MODEL CCR G0020 12VAC 60HG 1800W----UL LISTED 6H14----E196854-----DC KING WAY PLUG PO 0800 PLUG
Mar 19, 2008 | Wolfgang Puck Kitchen Appliances - Others
Garden Logo
113 people viewed this question
Top Electric Garden Experts
Steve Oakes
dannydoesita
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
