TV at standby condition. Not turns on from panel buttons or remote control..(Tariq Khan)
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Mar 30, 2015
I need to get to av without a remote control
Sorry I can't tell by the video but on the side is ther a menus button? And if ther is push it and go to the channel selection or add/remove channel or where u see a place to do a auto detect.. Once there u should see a add selection and u can add channels manually with the + - buttons as up and down u should be able to add the av to the section list or it will just let u select that Chanel and exit the menu automatically.. Or u can get a universal remote pretty cheep prob like 5 buck at Walmart and do it that way or if u have cable or dish that remote will program as well.. Good luck
Jan 15, 2013 | Televison & Video
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
Aug 21, 2012 | Polaroid TLX-01511C LCD TV
Turn stand by off without remote?
If the set is turned off to standby by its remote control, you must have its remote cotnrol to power it ON. No buttons on the front panel will work at this condition.
May 16, 2012 | Televison & Video
I have lost the remote control now the tv will not turn on
The remote should not have any effect whether the T.V. turns on or off.
Have you tried to press the power button so that the standby light is on? On most Tv's the light should be red. Once the standby light is on press the button on the TV to change the channel, either the + or - button. This should switch the tv on.
May 03, 2011 | Televison & Video
I need the code number of tv to enable me to use sky remote control
Please try 0863 for Hyundai Televisions To program your Sky remote control using the 4 digit code
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Press the TV button on the Sky Remote again
  5. Enter 0863
  6. The LED should blink twice, if not recheck the 4 digit code used and go back to 1
  7. Press the standby button on the Sky Remote (The TV should go to standby)
  8. Press the Select button to store
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Please keep me posted.
Thanks.
Lor04
Apr 06, 2011 | Hyundai Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
How do I over ride the password setting
Hello
I thinks that you have forgotten the password. There is a way to reset it.
[1] Make sure the your TV is on standby condition. That is make it standby with the help of remote handset.
[2] Press Volume _ [negative button] on the TVs Front panel and then the "Clear" button on your remote handset for approximately 5 seconds. Keep both of them pressed at the same time during this 5 seconds. The TV will turn back on.
[3] Enter a new password on the next time you access the PARENTAL CONTROL or the TIME menu.
Oct 20, 2010 | RCA 27V530T 27" TV
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Sony KV-32FS200
I read the manual and it says in the FAQ.
Q- TV doesn’t turn on
after disconnecting
the TV and timer
LED flashes
❏ Press the POWER button on your remote control or in the TV front
panel, one more time.
Tell me if it works...
Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
