Question about Home
Where would would i get a clip to connect to the rubber tube inside the toilet
    Master:
  • 395 Answers
If you mean the small clip that attaches to the exit tube and hold the water line in place, you can't get one.
Just run the tube into the exit tube and it will sty there.
Posted on Mar 30, 2015
How do you stop a kohler toilet from spraying water inside of tank lid
There should be a small hose that is spraying the water. That hose should be put inside the overflow tube and heald in place with a clip or put into a small hole on top of the tube. Only put the tube in just enough to hold it in place. If it is spraying from anywhere else you need to replace or repair the ballcock.
Nov 13, 2014 | Kohler - Toilet - Two-piece - Highline -...
Have the Toto Ultramax II toilet and it was installed 3 months ago. Have an issue where the GMAX fill valve is not functioning properly. The water keeps running because it always go over the fill line....
An installation guide for your toilet can be found here:
http://admin.totousa.com/Product%20Downloads/0GU013Z,%20ONE%20PIECE%20TOILETS,%20V.08.pdf
See the top of page 5 for guidance on setting the water level. Make sure you are turning the screw the correct direction (clock-wise) to reduce the fill level.
Is the refill tube properly connected? Should be connected to fill valve nipple and the other end clipped to direct flow to the inside of the overflow pipe.
Is water flow only through the overflow tube or is there leakage from the flush valve? Being only 3-months old you should not be having problems due to breakdown of rubber seals; however, check to make sure the toilet flapper is properly sealing against the flush valve.
If none of this helps with your problem you made need to replace the fill valve. On page 10 of your guide is a parts list; you can identify your part numbers and shop on-line for an idea of replacement costs:
https://www.totostore.us.com/e2wShoppingCatalog.aspx?parentId=3100066448&parentLink=2100000107:3100066448
Jan 19, 2011 | Toto MS853113S#11 UltraMax Round Toilet,...
I recently replaced the flush valve with the fluidmaster repair kit. Now I don't get any water coming from under the rim of the bowl when flushed. I noticed the rubber gasket wasn't the same, does this...
No, that won't make a difference. Check instead that the tubing from the fill valve that you replaced is connected to the overflow tube (the tall tube). Fluid-master provides a clip for this purpose in their kits.
Best regards,
--W/D--
Jan 13, 2011 | Kohler Home
The bowl on one of our Toto Drake toilets, after a flush is complete, has very very little water in it. I recently replaced the fill valve (used a Korky fill valve). Since then I have had this problem
The small tube that comes from the Korky fill valve needs to go down the center of the tube in the tank. It should have come with a clip to clip it inside the fill tube. If the tube is running water into the tank it is just filling up the tank, not the bowl. The tank is filled with the Korky valve from the top of the tower, not the black hose. See the video below to see the black tube I'm referring to and where it should be attached.
http://www.youtube.com/watch?v=bfE8gBV0gHI&feature=player_profilepage#t=92s
Jan 10, 2011 | Toto Drake 2pc. E/F Toilet CST744S-01
The little hose that attaches to and pours water into the long vertical tube (to fill the tank) has slipped off twice and sends water over the side of the tank and floods my bathroom floor. The little...
to get a new one would require a new fill valve for your toilet, or a local plumber might have one rolling around on his truck.
try a paper clip, one thats a little bigger than the tube. slide it onto the tube, then clip it onto the fill tube like you would a piece of paper, this works in most cases.
Aug 17, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Keeps clogging
Have you check the toilet for proper water level in tank. Level will be near mark on overflow tube or within 5/8" from top or it adjust float if not to get it there.
Next is the fill line 1/4" poly line connected to fill valve to overflow tube to allow proper amount of water in bowl.
Port's under the rim are clear on not clogged you can use a nail or paper clip to push through thes to clean out. You can't see them they are under the rim of the bowl.
If something fell in bowl and got flushed it could be hanging up in the trap in the bowl. If you have some rubber gloves check out drain in bowl before trying to use something to push it further in the drain.
If nothing found maybe try a 6 ft auger you can get these fairly cheap and they are handy to have around.
May 30, 2010 | Eljer Toilet Onepiece Canterbury ...
Toto flapper seems ok but toilet keeps slow trickle into the bowl
The water inlet valve should close completely and stop water from coming into the tank before the water level reaches the "small tube." (This is the overflow tube.)
There may be an o-ring or rubber gasket inside the valve that can be replaced. If not, you would have to replace the water inlet valve.
Oct 16, 2009 | Home
Water shoots out when i flush
either your fill tube came out of the tube in the center that the flapper is connected to or the fill valve wore out.Usually this happens when the little plastic or rubber hose coming off the fill valve comes out of the over flow if you secure it to the center tube so the water goes down it you'll have a dry floor and better working toilet
Aug 11, 2009 | Home
Where could I find the flapper for Sterling 1.6GPF toilet?
Here's the easiest way: Close the water valve that supplies water to the toilet. Lift the lid off of the tank. If you look in from the top, you'll see a long white tube in the middle of the tank running from the top to the bottom. It is called the overflow tube. At the base of the tube is the flapper, and it anchors to the base of the tube, and is actuated by the handle on the front of the tank pulling the chain connected to the flapper. Flush the tiolet, and you'll see what I'm talking about. To replace the flapper, you'll need a replacement. Remove your flapper and get a pretty good look at it. You can buy a replacement at any hardware store. A 'universal' replacement should fit, but take the old one with you to be sure. When you look at the new flappers, you'll notice a rubber ring attached to the flapper, and you may not have one on yout toilet. No worrys here, the ring can be cut out if yours is of the type that just clips onto two lugs at the base of the overflow tube. Install your flapper, hook up the chain and turn the water back on.
The chain should have just a little slack in it.
Best regards, --W/D-- please feel free to rate this solution....Thanx!
Aug 02, 2009 | Sterling 402315-96 Biscuit Windham...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
