WHERE TO PURCHASE A PROJECTOR BULB FOR A SANKYO DUALUX 1000
    Master:
  • 395 Answers
Type the manufactures mod. number in the command line of MNS.Com and it will make suggestions for you.
Posted on Mar 30, 2015
Where to purchase a bulb for a sankyo dualux 1000 projector
Try eBay: Just type the bulb mod. into the command line and away you go.
Mar 30, 2015 | Office Equipment & Supplies
What size/diameter is the belt for the Sankyo Dualux 2000h 8mm projector (belt from moter/fan wheel). Mine is so stretched that I cannot use it as a replacement guide.
My PRB belt guide says to use an OC7.0 which is a round rubber belt with a circumference of 7" and a cross/section of .139".
Jan 11, 2015 | Office Equipment & Supplies
We just purchased a lamp for our HD20 projector, and after less than100 hours our picture looks like a Charles Schwab commercial. (http://www.actorbillhoag.com/) Any suggestions?
I would remove and replace the lamp to see if this works.
On my projector lamps for a different brand of projector the site I buy my replacements from states that if the bulb is under 1000 hours old and fails then it is covered by a warranty and this may be the same with yours.
If the old lamp is still around then I would revert to the previous one just to isolate the issue to the lamp.
Dec 14, 2011 | Optoma Office Equipment & Supplies
Our picture is faded and the brightness is completely washed out the bulb has 1000 hrs on it does it need to be replaced?
yes it certainly seems like. the DLP engine won't have any age related issues, which means it must be the bulb.
I realize that 1000 is not what you'd expect for a bulb, but frequently manufacturers quote bulb hours on diminshed or even minimal settings.
bulbs are available for much cheaper online, even some reputable dealers on ebay. Just be sure to check their feedback!
Mar 03, 2011 | ViewSonic PJ402D DLP Projector
How do I replace drivebelt on sankyo dualux 1000 projector
Inside parts:
Small belt wheel (SBW)
Large belt wheel (LBW)
Motor Assembly (MA)
Fan Blades (FB)
Fan Blade Cover (FBC)
Make sure you have magnetic screwdrivers.
Remove MA - 4 screws.
Remove FBC - three screws
Loosen LBW and slide down shaft a small bit away from end. Need small Allen wrench.
Slip new belt around LBW (takes some fiddling).
Put LBW back to previous local and tighten.
Reattach FBC.
Put motor in place.
Stretch belt over FB and onto SBW. (It will make it.)
Screw in motor.
Good luck.
Feb 21, 2010 | Photography
Specification for the drive belt
I already got solution for this problem.
Thanks
Dec 16, 2009 | Cameras
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
Cinego d-1000 starts with picture and then shuts down
the warning doesn't come on all projectors. Replace the bulb anyway!
Jan 26, 2008 | Radio Shack Cinego D-1000 Multimedia...
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
Removal of projector bulb housing
HBE  1-800-848-6888 TY-LA-1000 ==PTL-010 complete housing
239.00, lamp only==229.00.
I never replace lamp only-------T.
Oct 23, 2007 | Panasonic PT-43LC14 43" Rear Projection...
120 people viewed this question
k24674
jasbo
jasbo
