Question about Eaton Powerware 9390 UPS System
I have an input AC under voltage error and utility out of limits error what to do?
    Master:
  • 395 Answers
Replace the internal battery.
Posted on Mar 30, 2015
Error code 16 coming up on my treadmill 956i
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Mar 28, 2014 | Precor Exercise & Fitness
Treadmill error code 16
Corrective Action
Precor Error 16
Precor error 15 input voltage
Precor Error 15, AC Input Voltage Too High Probable Cause 1. AC input voltage is incorrect.
2. AC input voltage transients. Transients can be caused by lightning strikes or by other pieces of equipment sharing the unit's AC power.
Corrective Action
  2. Ensure the AC grounding for the unit's outlet is good and verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error Code 15
May 18, 2013 | Precor C966i Treadmill C 966i
Motor error messege on E25 sole ellipticle
proceed according. God bless youDescriptionThis error monitors the treadmills power bit reading. Power bits indicate the relative time that themotor controller drive circuit is turned on. Therefore power bits is an indication of the amount ofpower the load is demanding from the motor controller. The treadmill software sets a maximumallowable power bit limit. Error 25 indicates that the maximum power bit limit is being exceeded.Possible Causes1. The running belt and/or running bed is badly worn.2. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor filter capacitorcould raise the current demand sufficiently to cause the error 25.3. On treadmills utilizing an SCR motor controller, a leaky or shorted drive motor inductor couldraise the current demand sufficiently to cause the error 25.4. A shorted or de-magnetized drive motor is causing the high power demand.Possible Remedies1. A clamp-on A.C. ammeter must be used to determine the amount of A.C input current beingdrawn by the treadmill under no load and loaded conditions. The current readings can beused to determine the condition of the running belt and/or running bed. These same readingsshould be taken on a similar unit with a known good running belt and running bed. Thosereadings can then be used as a benchmark for future use. Replace the running belt and/orrunning bed as required. Remember, many running beds are double sided and the bed canbe flipped over rather than being replaced.2. A clamp-on ammeter should be used to measure the A.C. input current at no load. The filtercapacitor should then be electrically isolated from the drive motor circuit. The drive motorleads must be kept intact so that the drive motor will operate with the filter capacitor removedfrom the circuit. The no load A.C. input current should be measured again, if the A.C. inputcurrent is significantly lower, replace the filter capacitor.3. Use the same procedure as in step 4 above, except remove and isolate the inductor from thedrive motor circuit instead of the filter capacitor.4. A known good drive motor must be substituted for the existing drive motor.
Apr 02, 2013 | RTO Sole Fitness Package F85 Treadmill &...
Precor c954i error 16
Corrective Action
Precor Error 16
Sep 08, 2012 | Precor C954i Commercial Treadmill
What is the problem on a C956i when error code 15 comes up? Can this be fixed by the user or does it require a professional?
Corrective Action
Sep 01, 2011 | Precor C956 Treadmill with Cardio Theater...
It has an error 15 that keeps poping up
Corrective Action
Mar 02, 2011 | Precor C956 Treadmill with Cardio Theater...
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
My tram 2512 is stuck in waiting for AC mode, ac is clearly reaching the unit, both by shore power and genset. What could the problem be?
If you are referring to a Trace 2412 inverter, which series is it? An SW or a DR series? In either case, if it won't accept generator power, but the AC input indicator is flashing, the problem is most likely the generator output power is off frequency or voltage. Trace inverters will only connect when the AC input is within certain limits. I'd suggest checking the frequency and voltage output of the generator. If it won't connect to shore power, check the voltage from that source. Make the voltage checks at the inverter input terminals.
May 11, 2009 | Xantrex Technology Trace Series Inverter /...
Eaton Powerware 9390 UPS System Logo
192 people viewed this question
Top Eaton Computers & Internet Experts
Lawrence Oravetz
pawnpower
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
