Question about Sewing Machines
Where do i find direction on the eyelet stich
  • Sewing Machines Master
  • 12,273 Answers
If your machine is capable of making an eyelet stitch, the instructions should be in the machine's manual.
Posted on Mar 30, 2015
    Top Expert:
  • 51,518 Answers
You mean button hole ?? google make /model/manual
Machine was working stiching, went to stich another piece of fabric and no stiches
Hai, You try to change a new needle Otherwise you take the small waste piece stitched after change the another piece of fabric start a stitching.
Apr 25, 2014 | Sewing Machines
My stiches keep missing a stich
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
if these suggestions don't help the the machine could be out of
time & the machine would need to be taken to a sewing machine
shop to be checked
Aug 06, 2012 | Husqvarna Huskystar 215 Sewing Machine
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
My machine doesn't stich at all even though I'm sure I threaded it right. Is there a special needles for serger?
Yes, there is a couple of different needle systems so you need to make sure you have the right ones as specified in your manual.
Also in the 130/705H system there is a couple of special types called "SUX" or "ELX" for extralong scarf, otherwise they are just the same as the standard 130/705H system needles with flat shank.
Check this link from the Schmetz needle website, its very informative on the different needles for each make and model
http://www.schmetzneedles.com/learning/overlock-needles.htm
Also check that the needles are fully up into the housing and both flat shank to the back and they will be at different heights, this is normal.
Getting it to chain off is usually a case of threading up the four threads in the order specified in your diagram, so make sure you have threaded the two loopers in the right sequence, then pull all the threads under the raised pressure foot and out to the back of the sewing platform, lower the pressure foot and start stitching, hopefully it will chain off. Its just about having the two looper threads coming out of the looper eyelets in the right position.
If you have tried the threading up multiple times and did strike something, then you may have knocked out the timing of the loopers causing the non stitching; if you suspect this, then time for a technician service.
Dec 12, 2011 | Singer QuantumLock 14T948DS Mechanical...
The stich is not tight
CHANGE UR STICH SIZE AND TIGHT UR TENSION DISK
Apr 04, 2010 | Riccar R651 Mechanical Sewing Machine
I need to know how to change the utility settings?
You have not said what model you have but I suspect that the other 11 stitches are stretch stitches which will mean you have a seperate dial to select, if you could email a picture of your machine I will soon know.
drivewithken@blueyonder.co.uk
Oct 30, 2009 | Necchi Sewing Machines
Draper eyelet punch
There are two sizes of metal........use one of each to create the eyelet.
Thread the longer one over the stalk shaped side, and the shorter one on the other side........if the fabric is lightweight, the clamping motion should also cut the hole as it engages to create the eyelet...if it is too thick, you will need a hole punch to clear the way first.
The action is for the longer shaft to pass through the fabric, then the inside edge of the smaller one, then the edges are bent and rolled but the flanged die to finish and secure......try a few samples on scrap first.
May 08, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
