Question about Keurig B60 Coffee Maker
Water got into back, machine now has no power, is there a reset button
    Master:
  • 395 Answers
If the Main Circuit board go wet, it may have shorted. Drying will not restore the controller. Replacement.
Posted on Mar 30, 2015
    Scholar:
  • 180 Answers
You might get lucky and it works again once it's dry, otherwise the water fried something and you may need a new machine or have yours repaired.
I have a LG top loading washer. Cold water will not shut off, making it so washer will not shut off. Water still runs after we unplugged the washer.
Close the cold water valve behind the washer, then try a reset. If that doesnt work, the timer may need to be replaced. Depending on your skill level, you could do it yourself.
To reset the washing machine:
  1. Press POWER to turn the washer off.
  2. Unplug the washer from the power outlet. ...
  3. With the power disabled to the washer, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in, or turn the circuit breaker back on.
Nov 28, 2016 | LG Washing Machines
Mw612 rest code
Was the motor controller or display board replaced.
You need to re-size these to your machine.
SIZE SETTING MODE.
To set the size switch,
turn the power on at the power point and off at the console.
Push and hold the WATER TEMP UP button then press the
POWER button.
To select the size of the machine,
push the temperature up button until the cold LED is on for
5kg machines,
push the water level up button until the low water level LED is on for
the 6kg machines,
push the SPIN SPEED UP button until the hold LED is on for 7kg
machines.
Apr 15, 2014 | Fisher and Paykel Washing Machines
Samsung front loader washing machine power cut out mid load
If by turning off the power you mean you hit the power button .... try unplugging the machine for about 15 seconds and then plug it back in ... this may reset the machine. If not you may want to call Samsung ...
http://www.samsung.com/au/info/contactus.html Hope this helps!
Nov 25, 2013 | Samsung WF337AA Front Load Washer
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    I have a Maytag top load high efficiency low water washer and the lid lock is locked and will not open. I was doing a load of clothes and power went off for just a minute and now I can not get the lid to...
    This is a common problem with a momentary power failure, the controller doesn't get time to reset and return to an idle state before the machine gets power back and it gets "confused". You will almost certainly find that unplugging from the mains (Not just powering off on the button, as some door locks have a sneak circuit, even when the power is turned off at the button) and leaving the machine undisturbed for a full 20 minutes will allow a reset, the door lock will disengage and all will be well when you power back up.
    Jul 05, 2011 | Maytag Washing Machines
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    LG Washer stops when it gets to rinse cycle
    Code flashing IE? The code means the machine is not getting enough rinse water. Remove the hoses from the back i=of the machine, pull out screens, cold water is blue tab inside connection on washer, hot water is red. Clean screens and insert them back into the appropriate connection. Use a stiff brush and water to clean. Reset the machine by disconnecting power, press start/pause button(blue button on right) for at least five seconds, reconnect power.
    Oct 31, 2010 | LG WM2277H Front Load Washer
    Can the HP 1040 fax be cleaned to remove the two vertical lines that print? How? There is no glass to be cleaned and it does seem that the machine can easily taken apart?
    This seems to a hardware problem. Resetting the machine fixes it most of the time.
    There are many levels in reset, please try the the next level if the 1st did not fix.
    Power Drain:
    * Turn OFF the machine, disconnect the power cable from backside of the machine and from wall outlet.
    * Press and hold the Power button for 60 seconds.
    * Connect the cable and turn ON the machine.
    Partial Reset
    * Remove the power cable from back side of the machine while its ON.
    * Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
    * If machine turns OFF, press power button to turn it ON.
    Semi-Full reset
    * Remove the ink cartridges.
    * Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
    * Insert the ink cartridges.
    NVM Reset
    * Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
    Regards,
    Riztech
    Sep 25, 2010 | HP 1040 Plain Paper Inkjet Fax
    I have letters le flashing on my lg front loading washer it won't spin
    Sep 25, 2010 | LG WM2277HBW XL Front Load Stackable...
    How to reset
    Steps:
    1)Press the reset button once.This will cancel the washing cycle and pump the water out of the machine.
    2)If the machine is unresponsive,kill the power to the machine by turning it off on the wall switch or turning the circuit breaker off.
    3)Leave the power off for 30 seconds,then turn the power back on.
    Jul 31, 2010 | Dishwashers
    Keurig B60 Coffee Maker Logo
    257 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Oloyede Monsuru
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
