Question about Arris Computers & Internet
Bought the same identical modem that time warner provides & had them register it.enabled wireless & rebooted modem. wireless disables when you connect time warner says everything is good on their end
Arris DG860A modem
    Master:
  • 395 Answers
The configuration between the modem and your computer requires digital switching via code settings. Check you manual for the proper communication settings.
Posted on Mar 30, 2015
NetGear Gateway Access Problem
No to warner's locking the modem. 192.168.0.1 is the correct address for accessing the options within the modem. incidentally the Motorola wireless modem works better. Go on line to Netgear technical service and they will guide you through the task of setting up the system.
Feb 27, 2014 | NetGear WG602 802.11g/b Wireless Access...
I keep having this problem with my wireless saying validating Identity. And I can not connect to the inernet
Hi
for resolving your problem Click the network properties and select wireless properties,go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
Chher
Jun 28, 2011 | D-Link DIR-615 Wireless Router
I have recently moved from Pittsburgh, PA to Charleston, SC. My linksys Wireless G 2.4 gHz router worked great with the ISP in Pittsburg (Comcast). Now, with Time Warner's Road Runner, I get an error and I...
Connect your main cmoputer directly to the time warner modem. make sure that your computer will be able to go on line when connected directly to the modem. If not then call Time warner.
If your computer is able to go on line when connected to the modem then your modem is working properly. You will need to change the settings of the router.
First reset the router for 30 seconds. On the router you will find a small reset button. Hold it down for 30 seconds. release it. wait for 1 minute. now unplug the power to the router and plug it back in. wait for 30 seconds till the power light on the router will be solid.
Now connect the modem and the computer to the router.
Now you will need to clone the MAC address of your main computer to the router. you will neeed to open the set up page of the router.
once your main computer is online , you can change the wireless settings of the router and connect to the wireless network on the laptop.
Click here for step by step solution
Apr 10, 2010 | Linksys Wireless-G Broadband Router
Wireless connection excellent / won't connect to internet
TRY TO CHECK YOUR CONFIGURATION... OR RE CONFIGURE AGAIN WITH THE CARDS.. MAKE IT SURE THE SETTING IS CORRECT. USERNAME AND PASSWORD YOU ENTERED.
May 26, 2009 | Trendware TEW-432BRP Wireless Router...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Setting up a wifi router
Configure the router first using the desktop. Make sure the modem is connected to the Internet port of the router and the desktop to port 1. Just run the setup CD that came with the router and it will guide you through the setup process. You can also try to reset the router first by pressing the reset button at the back for 10 seconds then unplug the power to the router and the modem, wait for 30 seconds. Power on the modem first and wait for the lights to stop blinking, then the router. check if the internet works hardwired.
Hope that helps.
If not, tell us more. Who is your ISP (Internet Serivce Provider)? Is it a cable or DSL?
Jul 24, 2008 | NetGear WGT624 Wireless Router
Dynex wireless modem
Your expert Geokohler helped me fixed the problem and soved it for me. I sent an evaluation giving him a "fixit" rating.
Jul 21, 2008 | Dynex DX-E401 Router
Connecting dlink WBR-2310
hi greci6,
Does your laptop have wireless access?
You may have to buy a wireless chip for your laptop, Give me a little more information on your error you get.
Also tell me how your router is setup, and cord placement.
Dec 31, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
231 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
