Question about Wagan Electronics - Others
Wireing the power dome 2354
I PUT A BATTER IN THE WAGAN POWER DOME 2354 NOT SURE GOT WIRE BACK RIGHT
3 Suggested Answers
nitrospawn
  • 290 Answers
SOURCE: Hi I have a Wagan 2012 5000watt inverter and it
i do not think they are but i will like you to refer to your invert manual
Posted on Feb 25, 2010
SOURCE: I need help in finding an adaptor for both DC and
pls i d;nt understand your qusetion clarifia it for me.
Posted on Feb 21, 2011
I need a manual
Use Google / Bing / Yahoo and make a search like this:
Wagan Power Dome Compact Generator manual [pdf]
Feb 04, 2016 | Wagan 2354 Power Dome Compact Generator
What's wrong with my dome and back light.? Fuses are fine but no power. Please help.
have you tried checking to see if you have power at the switch itself if you have no power at the switch you may have a break in the wire or a bad ground on that circuit
Jan 12, 2015 | Cars & Trucks
How to wire domelight in rosen overhead dvd player
put dvd purple wire to the car gray wire your traverse has positive trigger. Hope that works , switch has to go to positive on dome switch . Please post back if that works.
Jun 27, 2012 | Rosen G10 Car DVD Player
99 neon dome light wire diagram
Hooked all wires up right??? Fuse is fine??? Somehow, I do not think this is the case. I wish I had a dollar for every time I have seen this happen....I would be a VERY rich man!
You do not need a dome lamp diagram. You need to replace Fuse #13 (10 Amp) in the Power Distribution Center in the engine compartment. This will make the power return to the PINK wire and get your dome lamps working.
The only way that the RED/WHITE wire is going to have power with the ignition switch off is if either the ignition switch is shorted to power or the RED/WHITE wire got hot enough to melt the insulation in the wire harness and short to another B+ wire. This wire is supposed to have power when the ignition switch is in the RUN and ACC positions. Make sure it is in the OFF position. If this wire still has power, then YES, you probably smoked the wiring harness. If this is the case, the dash should be removed so that full access to the wiring harness can be achieved, allowing a full inspection/repair of ALL of the damage (there are most likely several other wires in the harness that have also been damaged).
Dec 24, 2011 | Dodge Cars & Trucks
I lent my wagan Powerdome to a friend and he lost the charger, where can I get one
raido shack they have all types look on the back to find out what the (amp) (voltage)and
you must no what the center of the plug is (posative) or (negative) if they dont have one
in the store they can order the wright one for that unit
i hope this helps you
bob
Aug 23, 2011 | Wagan 400 Watt Power Dome
Lost charger for Power Dome Model 2354. Need to replace charge and to be sent to Orlando, Florida address.
You can purchase one from Wagner on this LINK
They are $5.00 Plus Shipping
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 02, 2011 | Wagan 400 Watt Power Dome
How do i tap into a 2011 buick enclave dome light to add led lights under the dash. I want them to turn on when the dome light goes on. Where would I find the positive wire for those lights
The easiest place for you to tap the Dome light power would be at teh fuse panel where the fuse is located. The ground for that to work is the little switch in teh door jam near the hinges. The problem you may run into is the dome light coming on when you activate the switch to turn those LED lights on. Your going to tap the power wire direct and put the switch to turn them on controlling the ground unless you want them to work at the same time the dome light does in which case I would tap the power line direct and then run an additional wire to tap the switch in the door. A better option, at least to me, would be to tap power off the lighter circuit and control that with the switch then you could ground anywhere you have a good ground.
Oct 27, 2010 | 2009 Buick Enclave
Have a 04 super cab ranger tremor and when i turn the dome light and the door ajar light comes on how can i fix that
turn off the dome light.
the door opens, it turns on the dome light, so the wire that goes from the door switch gets powered up and makes your dome light come on. if your door is closed, and you turn on the dome light, the same wire gets power and is actually sending power to your light bulb on the dash.
just ignore it , or get a diode and put it on the correct wire, and it wont allow the electricity to flow back towards the light bulb when you put the dome light on.
Jul 31, 2010 | 2004 Ford Ranger
Wagan 400-watt power dome jumpstarter...
Wagan 400 watt power dome. How to charge the battery when out of car?
Sep 26, 2008 | Wagan 400 Watt Power Dome
Electronics - Others Logo
Top Wagan Electronics - Others Experts
Are you a Wagan Electronics - Other Expert? Answer questions, earn points and help others
