Question about Home Security
I am watching a relatives house and the alarm keeps going off when I sit on the couch. They never set the alarm. Not sure why. Now I can't reset it
4 Suggested Answers
  • 17 Answers
SOURCE: lost manual can't reset time or turn off alarm
Hi Cheese,
Please use the link below which has the information to reset the time
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw5057.pdf
Posted on May 14, 2009
  • 183 Answers
SOURCE: I have a square Freestyle watch. It keeps beeping, can't trn off
You can try taking the battery out and waiting a minute or two then replace but you should probably have a watch maker/technician "AC" or clear the watch. This involves resetting the circuit board and only takes a moment. I would also have them reseal the watch and pressure test it as Freestyle's are made to be in water and you will want to maintain the water resistance.
Posted on Sep 17, 2009
SOURCE: My car alarm keeps going off by itself. This
I have exactly the same problem! There is some water in the rubber gasket around the hatch and also on the latch, so I suppose there's water leaking in and disturbing the sensors.
Posted on Jan 25, 2010
I have a g1100b. having problems setting the alarm. I keep setting it to 0600 but the alarm consistently goes off at 1300 daily. any ideas of how to set the alarm correctly?
If the date changes at noon then you just need to cycle through another 12 hours to be sure that it changes at midnight. It sounds like your clock is off by 12 hours.
If this doesnt work then have the watch AC'd or reset. This might correct a problem with the circuit board.
Sep 18, 2009 | Watches
Sep 17, 2009 | Freestyle Shark Predator Wrist Watch
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
 A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
Jan 24, 2009 | Casio Sea-Pathfinder SPF40-T Wrist Watch
Need instructions for setting a Sharp watch model # 2092
All the settings seem to go through the start/stop button. If you hold it down for 3 (not 2, not 4, but 3) seconds, it toggles in and out of "set the watch mode". You can tell you are in it because the seconds at the bottom go all blinky. Use (quick press) start/stop to move from seconds, to minutes, to hours, to year, to month, to day. Mode subtracts, reset adds. To set alarms, etc, first put the watch into Alarm Mode (Mode button, again).
Use the reset button to move to the selected alarm (1-5).
Hold the start/stop button for 3 seconds to toggle into "set the alarm mode".
Quick press of start/stop moves between things to set (kind of alarm, hours, minutes).
3 second hold of start/stop takes you out of setting mode.
Jan 05, 2009 | Sharp Stainless Steel Code Ii Analog...
I just got a Freestyle Tide Watch 3.0 for Christmas. I set the alarm, and now I don't know how to turn off the alarm. It only seems to give me the option of which days I want the alarm to go off, no...
I had the same problem. Emailed Freestyle support, it's pretty simple: Go into the alarm setting, and before you do anything else, push the reset button. That'll clear it. If you push the set button first, that'll put it in the set it mode, and the reset button will just advance you to the next setting.
Dec 26, 2008 | Freestyle Shark Tide Data 4 Alarms All...
GapKids Watch turning off the alarm
If you don't have the instructions, the buttons are labeled as follows:
Top Left is "Light" - Button A
Bottom Left is "Mode" - Button B
Top Right is "Start" - Button C
Bottom Right is "Reset" - Button D
With the time displayed, press the reset ("D button as listed in the instructions) and the alarm time should be displayed. While holding the "D"/reset button down, press the start or "C" button to toggle the alarm on or off.
Hope this helps
Dec 19, 2008 | Nike Triax Fly WK0006 009 Watch
Activate T Buton gose to Alarm function.
As with many watch manufacture houses novadays watch technology differs from house to house. Tissot is no difference as T-series watches was developed by Tissot itself.
You have to follow the steps one by one as instructed in your watch manual. Probably you will need reset your watch completely, depending what actions you've allready done.
In case if you lost your watch manual, go to www.tissot.ch and find out everything you need.
Regards
Arthur
Dec 16, 2008 | Tissot T-Touch T33159851 Wrist Watch
I just bought a Mondaine travel alarm pocket watch. Instructions say the crown has 3 positions. 1> Home normal for a quartz watch. 2> Pull out 1/2 way to set alarm. 3> Pull out all way to set time. My...
It seems like your watch has a little short stem and that's why it has only 2 positions. This does not affect battery in any way, nor the timekeeping.
The only downside of this is that you can accidentaly reset alarm time without knowing it as your watch crown is in permanent 1/2 way position.
If you are happy with that - keep your watch.
Dec 12, 2008 | Watches
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 | Watches
Home Security Logo
220 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
