Question about IBM Wheelwriter 30 Typewriter
I set my margin all the way to 0. However, after I type and hit a return, the carriage doesn't come back to the left margin. It is almost like it returns to an indented margin. We have 2 typewriters, and they both do the same thing. Help! I don't know how to correct it! Appreciate any assistance you can give me.
    New Friend:
  • 18 Answers
Try pressing Code + Return, it should delete any temporary margins.
Posted on Mar 31, 2015
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Your problem is one or more of a few different situations. First, you can clean the shaft that goes through the carriage. Look closely at where the shaft goes through the carriage and there is probably some built up debris (fuzz, hair, dust). remove it with a pointy object. Once this is clean, you can flush it out with some contact cleaner and then put some thin oil on the shaft and move the carriage back and forth. Another part of the problem is the motor that makes the carriage go back and forth. This is called the transport motor. You would have to remove the case to get to it as it probably needs flushing and oiling as well. I do not recommend for a novice to attempt to remove the case as you can break the clips that hold it together.
Posted on Mar 30, 2015
Brother ml 500 memory typriter how do i move margin to right
Use your space bar to move carrier to desired location, hold down Alt key button on bottom left (next to space bar) and press the number 5 numeric key on top row. That should set your right margin.
Jul 30, 2014 | Brother ML-500 Typewriter
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
My carriage return is stuck between 70 and 80 and I don't know how to get it back to 0 to 10. I hit return and the carriage goes back to between 70 - 80.Can you help me?
Return to the L. margin, touch and release the mar rel key, backspace to where you want the margin, press L. mar. key.
DickyO
May 20, 2010 | Nakajima AE-710 Typewriter
AE-710 Typewriter: My carriage return is stuck between 70 and 80 and ...
Return to the L margin, press don't hold the mar rel key, backspace to the desired location, press left mar. key. The R. margin works the same.
DickyO
May 18, 2010 | Nakajima AE-710 Typewriter
Can't get the left margin to change, it is stuck way over on the right side and when I hit return it goes to about the center of the typewriter
On carriage return the machine locates LH margin. In your case the LH margin is set in centre.
Press the margin release key when at the margin location position.
Use the backspace key to return to the extreme left.
Space forward to were you want the new margin.
Press Margin Left set.
Alan
Nov 04, 2009 | Swintec 7040 Typewriter
How to clear and set margins and tabs please on
You must hit the carriage return button to find the current position of the left margin, then hit the mar release button and use the backspace key to move the carriage to the new position that you want the margin to be set at, then hit the left margin key to set it. Then move the carriage to the right to find the right mar, hit the mar release key and use the spacebar to move the right mar to the new position you want, then hit thr right mar kay to set it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 02, 2009 | Office Equipment & Supplies
How do I get the left hand margine to release on my Royal typewri
Generally yoy can set the left margin all the way to the left by holding down the left margin key and pushing the carriage return button
Mar 23, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Return sticks
Try putting a few drops of light oil on the shaft that the carrier rides on and the pulleys that the cables are on (WD40 works well) also look for debris under the carrier.
Merry Christmas
DickyO
Dec 27, 2007 | Nakajima AE-740 Typewriter
IBM Wheelwriter 30 Typewriter Logo
128 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
