Question about GE Microwave Ovens
My GE microwave wont start. When you press the start button after entering a cook time it displays the word "fo od" then clears the screen and does nothing.
  • GE Master
  • 17,173 Answers
This is most likely the door switch. FO means failed to operate and OD means open door. You can order the part and replace the switch.
Posted on May 13, 2015
WhIzAtIt
  • 136 Answers
SOURCE: Microwave stopped working
There is a internal locking mechanisim that has 2 or more switches that is usually attached with two or more screws next to the door latch side. Crack open the micro and adjust this by shutting the door then pushing this assy toward the latches untill all the switches look like they are being pushed in fully. If this doesn't solve the problem one of the switches or possibly more are defective. Call a local appliance repair center and get a switch there called micro switches.
Posted on Sep 15, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Hi. I pressed the 'quickstart'
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Posted on Sep 28, 2008
SOURCE: Our microwave stopped working suddenly.
It's one of the micro-switches (3) that are part of the interlocking safety circuit. I actually took my switch apart and fixed it, but 99% of those out there would (and should) replace the switch.
Posted on Jan 16, 2009
  • 140 Answers
SOURCE: Ge microwave model JVM1190WY buttons work but does not cook
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
How do you set the power level? The model number is: JVM1730DM1WW The serial number is: MM901698B
Assuming your touch pad is working properly, press Time Cook (for cooking) or Time Defrost (for defrosting) and then type in the length of time that you want the microwave to operate. Then press Power Level and type in a number from 1-10. Finally press Start. Depending on the GE microwave, the Power Level button may be above 2 or to the left of 0. (I've seen both keypad designs depending on when and where the microwave was manufactured.) If you press Power Level before setting the cooking time, the unit will reset when you press Time Cook or Time Defrost.
GE has the manuals for some of their microwaves on their site. See http://www.geappliances.com/service_and_support/literature/ and enter the model number in the search engine.
I hope this helps.
Mar 02, 2011 | GE Microwave Ovens
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
GE Spacemaker microwave oven - Sensor error
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Microwave Ovens Logo
108 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
