My washer/dryer combo has 1 cord 220 yes it did work I washed serveral loads then I went to wash another and it want run fill up or anything
  • Washing Mach... Master
  • 932 Answers
Also, check your circuit breaker to make sure that has not tripped.
Posted on Mar 30, 2015
    Sergeant:
  • 249 Answers
Check the fuse in the plug first.
If it is a good fuse, then you need to call an engineer as the problem is likely on the circuit boards inside.
There may also be a reset switch somewhere on the casing that trips if the dryer has got too hot. You just need to press it until it clicks to reset it.
  • 37 Answers
SOURCE: Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Posted on Jan 17, 2008
jaylex
  • 417 Answers
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Posted on Feb 05, 2008
mastatech
  • 478 Answers
SOURCE: We just purchased a top load Kenmore 800 washer
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Posted on Mar 13, 2009
SOURCE: Supra Wash/dryer combo Model SW5l30D
check the heating element for power.
Posted on May 03, 2009
SOURCE: GE WSSH300G0WW front load washer
Had same problem with GE wssh300 front load washer. Removed two screws from front bottom panel (under washer front). Pulled off panel, loosened screw from a seal ring on the rubber flex hose going to a 4" square plastic housing. Reached down inside and found a ton of lint (probaby a 2" balls worth) jamming outlet. Removed lint an works geat. Very easy to do by tilting front of washer up and putting supports under front to keep elevated. Be careful to make sure supports are sturdy washer can't dop when servicing.
Posted on Aug 25, 2009
Washer won't turn on unless dryer is on
I assume you have a gas dryer, as a washing machine runs on 110 Amps while an electric dryer uses a higher 220 Amps. If both the washer and the dryer cords are plugged into the same socket, and the washer only runs while the dryer is on, the socket is not wired properly. You may check this easily enough by switching the washer cord to the one presently utilized by the dryer. If the washer runs, then look at the wiring.
Mar 04, 2015 | Washing Machines
I have a Kenmore Laundry Center.I washed 1 load then started another wash load. The washer filled with water completed the wash cycle and did not spin. I cannot get the washer to start again by...
Be sure there is power is coming from wall outlet and be sure breaker hasn't tripped. Also if there is a loose connection where cord was installed to unit, there may be a burnt wire.
Sep 11, 2017 | Washing Machines
Its about my washer/dryer combo whirlpool model lte6234dqs: -the dryer don't produce hot air and therefore don't dry. -Anybody please?
check your breaker to the appliance you must have 220 volts before it will heat if you only have 110 volts it will run but not heat otherwise it could be a thermostat or heating element which is hard to say with out me being there to check it out with a meter
Nov 19, 2010 | Whirlpool LTE5243D Top Load Stacked...
Washer not working
Hello, It is most probably either the water valve shut or the hose kinked also check that the drain hose is not blocked also.
Hope this helps.
Thanks
May 23, 2010 | Whirlpool LTE6234D Top Load Stacked...
Slim-Twin washer does not start
I've been researching this model a little bit, I think there are 2 fuses inside, but I dont know where. If I have to take mine apart, I'll let you know.. Did the machine ever run, or did you just get it. Is there 2 cords to your machine a 220 cord and a 110 cord, or does the washer just run off the 220, but your washer doesn't work, so you dont really know, but if it has two cords, could you let me know, so I can find the end of mine ha..thanks chuck
Mar 06, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Washing machine
Check the filter on the inlet holes, if that is good. Replace the water valve. hop this will help you.
Apr 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dtronics,
handiman518
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
