Question about Hoover Maxextract 60 Pressurepro Carpet Deep Cleaner, Fh50220
Help on max extract model FH550220
Leaking from the attachment hose trigger area even when this is not being used. acts as if it is not closing enough at the trigger area what to do
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: attachments
Most likely will have to replace either the nozzle valve or the hose comes complete, so if the nozzle pieces are available, then replace the complete hose asm.
Posted on Jan 05, 2008
impinokio
  • 7 Answers
SOURCE: my steamvac leaks from the clean water tank
you have either a cracked housing, or a valve is stuck open. if you can spray a small amount of wd49 into the valve, and work it a little, youmay be able to dislodge whateverdeposits have built up in there.
Posted on Jun 21, 2009
My Hoover Max extract dual v cleaner worked fine cleaning the carpet but when it came to using the hose attachment for my sofa, there was no suction and the brush did not spin.
Hello, Kathy -
If you have not yet checked your owner's manual; the Troubleshooting section, I suggest you do.
If you do not have the manual, you can download a PDF (Adobe Reader) version here:
https://www.manualslib.com/products/Hoover-Max-Extract-Dual-V-6126442.html
This is the link to the Troubleshooting section in the manual:
https://www.manualslib.com/manual/389163/Hoover-F7411900-Steamvac-Dual-V-Wide-Path-Deep-Carpet-Cleaner.html?page=19#manual
I hope you made sure the dirty water tank was empty and that the filter screen is clean.
Jan 02, 2018 | Hoover Vacuums
Why is water pouring out the bottom when I try to use upholstery attachment?
On many hoover models the hose attaches to the vacuum and is held on by a clip on the hose assembly. There may be some damage to your hose or the place where it attaches to the machine. Inspect these areas trying to locate the point of the leak.
Feb 25, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover max extract 77 manual
Hi! Follow the link below to view the manual for the FH50240. Hope this helps!
http://hoover.com/file/611/
Jul 19, 2014 | Hoover Max Extract 77 Carpet Cleaner -...
Hoover max extract leaks from end of upholstery hose
Hello! The nozzle/valve assembly, the white piece at the end of the hose that releases the solution may be clogged with build-up residue. Try soaking the trigger end in warm water for a few hours. If this does not help, the nozzle/valve assembly may need to be replaced. Order the nozzle/valve assembly by following this link. Search Results or order the complete hose assembly by following this link. Search Results
Hope this helps!
Jun 06, 2014 | Hoover SteamVac F5914-900 SpinScrub...
On my rainbow e series the power nozzle roller isn't spinning when I press the trigger even though all power is working fine. The roller is fairly new. I've also checked that nothing is blocking the hose...
Power must run from the vacuum through the hose where the trigger mechanism closes the circuit and allows power to pass through the hose to the wand, then to the power nozzle. A short or bad connection in any of these areas will cause the power nozzle motor to not run.
Oct 09, 2013 | Vacuums
Every time I use my New Hoover steam vac it leaks all the time I've tried every thing, I even bought a new tank same problem, I'm not taking it to be repaired its the 3rd one thats done it an
After the second time I would have asked for a refund. Maybe you need to do some diagnostic work.
1. Does it leak while sitting unplugged?
2. Does it leak while plugged in but not being operated?
3 Does it leak when the solution is above or below a certain level.
4. Are you over filling it?
5. Does it leak only when you pull the trigger? (valve problem)
Keep asking yourself questions to discover where and why it's leaking.
Good luck.
Nov 13, 2012 | Hoover Max Extract Steam Cleaner
The solution won't come out the bottom of the
You can check a few items:
(1) Is the solution supply hose kinked closed at the bottom of the handle?
(2) Any chance anything clogged the solution line? If anything solid got in the solution tank, even if somebody used powdered soap, it may clog the line.
(3) When you pull the handle trigger with you finger, do you see the rod press down a rubber pad (right behind the base of the solution tank area that it seals to the handle?
Nov 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
May 26, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Hoover Maxextract 60 Pressurepro Carpet Deep Cleaner, Fh50220 Logo
42 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
