Question about Sewing Machines
I have bought a serial adaptor to connect my scan and sew to my laptop but I it keeps saying it can't find the com port. How do I get to to recognise the adapter?
    Sergeant:
  • 249 Answers
Depending on the age of your computer, the COM port may not be connected or enabled.
When you start your computer, look for the command (usually DEL) to enter the BIOS.
Don't change anything but carefully search through the pages - the mouse doesn't work so you will need to use the cursor keys to move around the options.
You may find that the COM ports COM1 and COM2 are disabled in BIOS.
Selecting one of them and pressing the <RETURN> key should allow you to change the settings. Some times you just have to press the + and - buttons or the <PAGE UP> or <PAGE DOWN> buttons to enable or disable these features.
Pressing F10 on the upper row of keys should allow you to save the new settings.
You might also consider using a USB to Serial adaptor which save you a lot of trouble if you are not familiar with the BIOS system. The adaptor automatically sets itself up to communicate with the external device, in your case the scan and sew.
Hope this is of some help to you.
Posted on Mar 30, 2015
Cant connect my artista 180 to my pc it says 'serial port engaged'
Try changing to a different COM port and make sure you haven't got any other applications running that might be using the serial port, even if you've nothing connected ... have you recently installed something that might be using the COM port ?
Nov 19, 2011 | Bernina Artista 180
Connecting scan n sew
adpoter on that aint suitable maby they make a parelle pci card u could use
Jan 27, 2008 | Sewing Machines
How do I connect a 180e serial cable to my usb computer when Artlink and CPS software specify serial port?
I've not successfully managed this ... trouble-is that although you can get USB-to-serial converters, most computers that only have USB ports do not properly 'recognise' COM ports, which is what your Artlink software expects to talk to. I still use an old PC with a 'proper' 9-pin serial port on the back in order to talk to the old Artista range of machines. One of the drawbacks of a 'throwaway' PC industry that expects the rest of the world to continually update everything in response to new interface standards!
Oct 08, 2011 | Bernina Artista 180
I have a 180 and tried to connect to my computer with a serial to USB converter, and downloaded Artlink on my computer. Keeps saying there is no connection to the serial port. Any ideas?
yes you have to make sure you have a com port free and ensure that that is the only usb port you use for that. if you use the usb slot for anything else it always says that the serial port is busy.you have to go into your systems on your computer and find the usb port and it should list the com ports. ou need to find one that is not in use. they will be com port 1. 2. 3. or 4. then you have try each one in turn on your computer to deduct which is slots are actually which number. its a bit of a fiddle but once done label the slot for bernina only.i only have three on mine and so i bought a powered usb 4 port hub and i use that in the other slots so i always have enough usb slots.hope this helps
Sep 17, 2011 | Bernina Artista 180
How do I connect my 165 to a computer with USB ports only?
Use the free Artlink software from Bernina. The cconnector... use a USB to Serial port converter cable. Best Buy has them *Dynex brand). Worked for me on an Artista 180.
Feb 22, 2011 | Bernina Artista 180
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Customiser 2000 will not connect to a laptop as it has a 9 pin serial port (female) and the laptops have a 15 pin (female) I have bought 2 different cables but none work it just says serial port did not...
Are you using a USB-to-serial adapter?
I *think* what the problem might be is that the COM port's not been set in Customizer. Within either of the Easy/Customizer apps, go to ScanCard>Communication Settings ... you'll open up a dialog box within which you can set which COM port your cable's going to use.
If you're compie savvy, you can go to the Windows Start button on Task bar>Control Panel>System>Device Manager>COM ports and SEE which COM port your cable's using.
But until your software knows what COM port your cable's using it will NOT recognize that you have one installed.
Please let me know if this doesn't help! Or if there's anything I can help with!! :)
Aug 01, 2009 | Janome Memory Craft 9000 Computerized...
Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Jan 06, 2009 | PfaFF Creative 7570
Artista v3.0 security dongle
I am using a docking station for my laptop that has a serial port.
Dec 26, 2007 | Bernina Artista 170
Kenmore l900l /Janome 9000
call the people who made your computer (hp, dell) and ask for a down grade to XP and that will solve most all your problems that you will have with vista. vista has built in things that you will not be able to run alot of your programs on.
Dec 17, 2007 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
