Question about Kipor Electrical Supplies
How do I fix overtemp error on my kipor generator
  • MatchstalkMan
    MatchstalkMan Mar 30, 2015
    Hi Daniel Kwaramba, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Which model number do you own?
    Sergeant:
  • 249 Answers
Not knowing exactly which model you are running, I would check the usual areas: -
  • Check the coolant level in the radiator and expansion tank. Don't just add water, mix the correct ratio of water to coolant for your climate.
  • Check the oil levels as the oil also plays a part in cooling an engine.
  • Check that nothing is obstructing the radiator grille.
  • Check there is good ventilation space around the gennie - that is, its not stuck in a corner or up against a wall..
  • Check the hoses are not blocked - when you remove them to check them, top up the fluid levels again after you reconnect them.
Hope this gives you something to work on.
Posted on Mar 30, 2015
My kipor 7000 diesel generator is burning avr. Replaced avr don't last beyond few days. Can someone tell me cause
You need to run these tests in the video to see the state of the alternator. How to test your Electricity Generator AVR Brushes and Alternator on... With this info we can assist you further. :)
The Generator Guru Team
Jan 11, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
My kipor KGE 6000 Ti generator overload light is on, and there is no current output
Speak to us and we can help you diagnose this error.
www.generatorguru.com
Dec 25, 2012 | Electrical Supplies
Kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
Sep 05, 2012 | Kipor RV Generator Sinemaster IG3000
Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Feb 19, 2009 | Kipor Electrical Supplies
I need a 5kW DC generator with -48v output.
I have 5kW generators that produce -48V DC. The problem is that unless your generator is designed to produce -48V DC it would be difficult to retrofit an existing AC voltage output with a DC output.
Nov 25, 2008 | Kipor Electrical Supplies
Electrical Supplies Logo
97 people viewed this question
Top Kipor Electrical Supplies Experts
jhnolson
Jay Finke
Jay Finke
ray gallant
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
